Old 11-28-2009, 02:33 AM   #11 (permalink)
Straight gasoline = 15 mpg, 30% diesel blend = 18 mpg
Here at present low octane gasoline is $3.25/gal and Winter diesel is $3.55/gal
$3.25/15 miles = $0.2167 / mile
(3.25x.7) + (3.55x.3) = 2.275 + 1.06= $3.335 / gal blend
$3.335/18 miles = $0.1853 / mile
A saving of $31.40 per thousand miles in fuel cost.
I am experiencing no smoking or misfire. I discount all fears of filter clogging, injector clogging or valve stem depositions. If I've misjudged the fuel system seal compatibility I'll pay a hefty penalty. If there were misfiring then I'd be concerned about the cat., but absent the misfire I expect it to have a normal life.
Old 11-28-2009, 02:37 AM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I presume you've tested to a satisfactory extent and found that under your conditions, 30% is the most effective blend?
Have you noticed a change in engine running temps? I found that with diesel, my engines tend to "feel" a little bit hotter, but I haven't actually recorded temps to find out, since ABA testing would require drain/fill cycles, and I don't have time/patience for that.
Old 11-28-2009, 02:44 AM   #13 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
When I am making bio diesel I usually burn one or two car tires, helps keep the world in check.
Old 11-28-2009, 02:45 AM   #14 (permalink)
It's a bit tough to get accurate test data with so many uncontrolled variables in actual driving conditions. 50% was definitely too much as indicated by poor cold temperature starting and idle as well as slight misfire under load. There were small incremental increases in mileage in the 10-30% range. My metering is not perfect, but I use the scan guage to judge consumption, then first add 1/3 diesel, move to the regular pump and complete the fill-up. Close enough to 30% for my purposes. Whether it is actually ideal..... can't say with certainty, but close enough for practical purposes.
Old 11-28-2009, 02:46 AM   #15 (permalink)
Running temperatures are normal, riding on the thermostat at 190 whether straight gasoline or blended mix.
Old 11-28-2009, 02:52 AM   #16 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I deleted my last post I need to get some sleep.LOL
Anyway very informative. I just might have to try this on my company truck.
Pressure Gradient Force
The Positive Side of the Number Line
Old 11-29-2009, 04:18 AM   #17 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.29 mpg (US)
Originally Posted by Christ View Post
I've run straight diesel in a gas engine.
I don't suppose you have any data on the FE with straight diesel?
Old 11-29-2009, 01:20 PM   #18 (permalink)
Does adding diesel fuel to gasoline in any proportion increase or decrease the overall octane rating for the fuel?
Old 11-29-2009, 11:40 PM   #19 (permalink)
I don't, unfortunately, and I haven't had to do it enough to really have gotten any reputable data to begin with. TBH, I've only ever owned two cars that could use a SG, and I'm driving one of them now... the other is my wife's.
When I used to put diesel in my cars, I was like 16-18, always running out of fuel, etc. Right now, I don't think I'd be quite as willing to do it, but I'm not really sure why... probably because I have a gas station next door, and I actually pay attention to my fuel gauge now.
I've read in older Briggs and Stratton manuals that you could convert most of their gas only engines to diesel... they say to expect a power loss of about 20-30%, and an economy increase (run time on a metered tank at X load) of up to 30%, if that helps at all. I've never converted one, or tested the theory with a small engine, though.
I'll tell you what, though... I can give you a single tank reading when I pull the van off the road... I'll put 5 gallons of diesel in 15 of gas, fill the tank, and drive it out, then refill with gasoline. Its not accurate, but you've seen my average, so it'll be kinda obvious if there's a big increase that something worked.
I dunno, actually... Diesel's knock rating is in Cetane, not Octane... I dunno how to measure Octane levels on my own, and don't have a test block to do it with, so I couldn't honestly say.
Cetane and Octane are "made up" numbers, which give you an idea of the chemical composition of the fuel... Cetane, at higher numbers, gives a higher chance of autoignition, which is desirable in those type engines.
Octane, on the other hand, measures the resistance to compression ignition, a completely different beast.
Cetane is an alkaline molecule that ignites under very low compression situations. It has a Cetane number of 100. The higher your oil fuel's cetane number, the lower compression is required to ignite it.
Read more: cetane number - Comparison to Octane Rating, Chemical Relavance, Measuring Cetane Number, See Also, External Links cetane number - Comparison to Octane Rating, Chemical Relavance, Measuring Cetane Number, See Also, External Links
The Following User Says Thank You to Christ For This Useful Post:
Superfuelgero (07-05-2014)
Old 11-30-2009, 12:10 AM   #20 (permalink)
I'd imagine any gains from diesel fuel are from the higher Btu content.
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 04:24 PM
Gasoline expected to remain cheap this summer Frank Lee The Lounge 0 04-14-2009 03:43 PM
Adding Acetone as an additive to gasoline - worthwhile? havok95z71 General Efficiency Discussion 14 01-18-2009 11:29 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
News: Shell rationing gasoline, diesel in Western Canada AndrewJ The Lounge 4 02-14-2008 08:26 PM
