Old 07-23-2013, 05:25 PM   #1 (permalink)
aero shaped windsock on a truck bed?
do you think there is any merit in a aero shaped "sock" velcro'd and strapped to the cab & bed and leave enough gaps at the cab area to inflate the sock? Or do you suppose it would have to be inflated and sealed to have a chance of working?
Old 07-23-2013, 06:03 PM   #2 (permalink)
I predict a lot of flapping about and rarely "inflating" to the desired shape.
Old 07-23-2013, 06:09 PM   #3 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
I think Frank's right. I have observed enough tarps that this would give me reason to believe it wouldn't work as well as a hard top. BUT, if you have a cheap/easy concept you want to put together and test out, I will gladly read about your results .
Old 07-23-2013, 06:33 PM   #4 (permalink)
Perhaps a framework that mostly holds it's shape would help. Still, flapping about is all aero badness.
Old 07-23-2013, 06:41 PM   #5 (permalink)
That's what I am thinking, but I would like to see how much benefit would come from the unsupported system -vs- supported system -vs- hard top. Especially when I am not the one paying . I remember one member making a boat tail for his car and seeing very small returns. He used a plastic shower curtain as the rear windshield and reported it flapping a bit, they may be related...
Old 07-24-2013, 12:39 PM   #6 (permalink)
The flapping is the same thing the air would be doing without the membrane in it. So your membrane does nothing.
Work From Home mod has saved more fuel than everything else put together.
Old 07-24-2013, 05:37 PM   #7 (permalink)
sock
There's a fellow in Lubbock,Texas by the name of Rufe who is doing this with big trucks for a boat tail.I think he's applied for a patent on it.Texas Tech's Aero Lab was helping him with wind tunnel work.
When I did my pickup I had a fan forcing air into mine to help prevent aeroelastic effects that Frank Lee has mentioned.
You can try it and if it 'hunts' you can go to plan-B and install any 12-VDC ventilation fan out a car ,van,or pickup.The power liability from the alternator load to provide the current will be drowned out by the savings from drag reduction.I know this for a fact.
PS in the commercial vehicle section of Hucho's textbook he shows the Koenig-Fachsenfeld/Kamm inflated bus tail of the 1930s which he said might be worth re-visiting.(you're barking up a popular tree)
Old 07-24-2013, 06:12 PM   #8 (permalink)
I should have clarified that I was only thinking and commenting on the "autoinflate" idea; as Aerohead points out, an inflatable that achieves a high enough level of rigidity should work.
Sven7 (07-24-2013)
Old 07-25-2013, 04:55 PM   #9 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The air you need to scoop up for it to remain inflated, causes extra drag.
It's essentially a parachute / ballute.
You'd need to accurately size the scoops for the minimum required scooping of air, position them where you can't get much or any aerodynamic advantage out of the inflated "sock" - then hope the advantage of the sock is enough to cancel out the drag from the scoop(s).
Old 07-25-2013, 06:42 PM   #10 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
You could inflate it with the exhaust...but you'd have to be very careful about any leaks.
Dark Aero-The world's first aerodynamic single wheel boat tail!
