Old 11-30-2021, 11:31 AM   #11 (permalink)
60-mph
Originally Posted by Cd View Post
I keep seeing this comment over and over.
I remember a comment that Darin made about how important that aero is even at 45 MPH.
Can someone suggest a direct link to some info on this ?
It gets frustrating.
* There may have been a specific case in which the comment had merit. Perhaps a Bonneville streamliner class vehicle, or the 1993 EV1 land speed record car at Ft. Stockton, Texas. Without the context, we'd be at a loss.
* We know that aerodynamic drag varies as the square of the velocity.
* And we know that the power to overcome aerodynamic drag varies as the cube of the velocity.
* Here's an aero power profile for the 2019 Chevy BOLT ( using Cd 0.31 )
35- mph = 2.3316-hp
45- mph = 4.9557-hp
55- mph = 9.048- hp
60- mph = 11.7468-hp
65- mph = 14.9351-hp
75- mph = 22.943- hp
85- mph = 33.3983- hp
95- mph = 46.6271- hp ( 1-mph over rated top speed )
* One thought, which could explain the comment, might have had to do with the 'cross-over point' velocity, at which aerodynamic drag just began to exceed that of the rolling resistance on a road load power curve for this particular vehicle. For this to be true for the BOLT would require Cd 0.142.
Honk if you have a small one!
Old 11-30-2021, 11:36 AM   #12 (permalink)
Most of us in this community know that mechanical drag is a linear function, whereas aero drag is exponential.
Vman455 posted Permalink#5 in vain.
aerohead (11-30-2021), Joggernot (12-13-2021)
Old 11-30-2021, 02:12 PM   #13 (permalink)
mechanical drag
* Road Load Horsepower leaves 'mechanical' drag outside, dealing solely with rolling resistance and aerodynamic drag, by definition.
* To go from the Road Load Horsepower to Brake Horsepower, you would introduce all the transmitted power inefficiencies between the tire/road interface, and engine's flywheel, including any engine-driven accessories ( differential, wheel bearings, CV-Joint shafts, propeller shaft, transmission/ transaxle, power steering pump, water pump, alternator, AC compressor, etc. ).
* EV power electronics, motor losses, transmission losses, heat pump load, cooling system pump, etc. would have to be factored in to compute an EV's 'brake' kilowatts and BSFC-e, on top of its Road Load Horsepower/ Kilowatts.
freebeard (11-30-2021)
Old 11-30-2021, 02:50 PM   #14 (permalink)
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
So we're nitpicking terminology?
Common speak and math jargon are two different things. And I'm not a mathematician. So you'll have to excuse me for using the common definition of the word "exponential."
Old 11-30-2021, 03:45 PM   #15 (permalink)
This term is commonly misused.
I stand with the common man.
But I repeat myself.
Old 11-30-2021, 04:49 PM   #16 (permalink)
Blacktree's Avatar
My mistake. Totally misunderstood your post.
Old 11-30-2021, 08:13 PM   #17 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I assume the speed that aero matters depends on whether you're talking about drag or lift/downforce, right?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
aerohead (12-02-2021)
Old 11-30-2021, 08:16 PM   #18 (permalink)
Cd
Ultimate Fail
Cd's Avatar
@ everyone : thanks for the replies !
Old 11-30-2021, 08:54 PM   #19 (permalink)
I get that a lot.
I was empathising with Vmann455 without necessarily agreeing. Or covering for my error.
It's hard to shepherd the hive mind. There was a major kerfluffle over the Template recently, people got banned.
My effort was to get people to say first approximation instead of rule of thumb. You can imagine how that went.
Blacktree (12-01-2021)
Old 12-01-2021, 03:10 AM   #20 (permalink)
Blacktree's Avatar
Sounds exciting.
I'm sure that template has its uses. But let's be realistic; it's almost a century old. Our knowledge of aerodynamics has come a long way since then.
