Old 03-23-2011, 04:11 AM   #11 (permalink)
The PRC.
Why not turn it into one of these ?
Old 03-23-2011, 05:54 AM   #12 (permalink)
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
There was an aerodynamic bug in 69 - it was called a Karmann Ghia. My dad and I had a three or four of them and I don't remember that it got appreciably better mileage than a beetle, but then I wasn't really paying attention in the days of $0.35 gas!
Old 03-23-2011, 07:49 AM   #13 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Have you considered a modern look, like the VW XL1?
Old 03-23-2011, 01:07 PM   #14 (permalink)
gtkid2002's Avatar
The Bug - '69 Volkswagen Bug Base
Oh man if I had a Ghia I would restore it and enjoy it. I respect people aeromodding them, but I couldn't do that to a car I've loved since I was 8.
Jakob- That was the new vw concept I couldn't think of. Something like that would be awesome, but it would look funny jumboed I think. I don't want to cut the bugs chassis much. The body would be fine, just not the chassis.
Botsapper - I like that design. Pity they didn't make it mass though.
I'll try and post basic sketches today sometime. They're not pretty, but it's at least on graph paper. I know I'll need to put it in scale with a vw chassis, I just have to rip mine that far apart.
I suck at coding! Woo!
1969 VW Bug - Daily Driver
1975 VW Baja - Current Project
Priors:
1989 Honda Prelude Si 4WS (RIP)
1995 Honda Prelude Si (Traded)
1980 Fiat Spider 2000 (Sold)
Old 03-23-2011, 03:21 PM   #15 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Our '71 Squareback (air cooled with mechanical fuel injection) routinely returned mileage in the low 40s on the highway. Goes to show how much difference aerodynamics really make.
I'm not coasting, I'm shifting slowly.
Old 03-23-2011, 05:32 PM   #16 (permalink)
gtkid2002's Avatar
I'm wondering though, with how basic the original system was, should I look at getting a FI setup or keep the carb setup?
Also, how is a rear engine worse for FE. I know it effects handling, but FE?
Priors:
Old 03-23-2011, 05:33 PM   #17 (permalink)
PSmodder lurker
A natural donor for a great retro project.
The Following User Says Thank You to botsapper For This Useful Post:
gtkid2002 (03-23-2011)
Old 03-23-2011, 05:45 PM   #18 (permalink)
The PRC.
There were FI versions of the VW flat 4 in Brazil in the 1970s. The advantage of FI is fuel cut off and better metering of fuel delivery.
Old 03-24-2011, 12:08 AM   #19 (permalink)
The later Type IIIs (like the Squareback mentioned above) used an analog electronic fuel injection system. The later Bugs (and Super Beetles) used a different version, also controlled by analog electronics.
I would recommend not using the original systems. They are quite primitive, all in all, and very difficult to tune and modify reasonably. I would consider something like SDS (Simple Digital Systems EM-4) or one of the Megasquirt variants. The latter requires you to learn a lot about how injection works and do your own fabrication and such.
The single-carb setup is less than optimal as well, I think. The long-ish intake runners tend to promote manifold wetting; the heat risers from the exhaust combat that but take a little while before they get warm enough. I might consider a pair of little tiny single-throat carbs instead, but I'm not a carb guy.
The need for getting cooling air into and out of the engine bay (into the top, out the bottom) will make for extra aerodynamic challenges.
-soD
Old 03-24-2011, 02:41 AM   #20 (permalink)
gtkid2002's Avatar
-soD
Well considering the SDS costs about as much as my last car.. I'm gonna have to hold off on that. I'm guessing a primitive FI system is better than a carb, but I might end up with a spare of each of those to tinker with if I play my cards right.
Botsapper - Thanks for the overlay. I didn't realize how close those actually came together. Granted one might be stretched a little more than the other, but they still seem to fit just fine.
Arragonis - I thought they were standard by '75. My bug has the plugs for the fuel pump up front at least, but I thought it was converted back to a carb.
My '80 Fiat has a Bosch Jet-tronic FI system I think, and as far as I know only the warm-up injector fails now and then, decreasing mileage.
Right now I'm gonna try for the FI system and run it stock, just to see how much an aeromodded body would help.
Priors:
