Old 09-21-2022, 03:10 PM   #1 (permalink)
New class A CDL driver
Aeromodding a 2021 Freightliner Cascadia
6 weeks ago a signed a lease to drive a truck pulling reefer trailers cross country. They pay a certain number per load for fuel, it I use more, it comes out of the pay line. If I use less it goes in my pocket
So here we are. I can't do too much crazy stuff but considering the 2023 is available with aerox package a la carte, I may buy some factory pieces, I may build my own.
So far I've been eyeballing the bumper extension/airdam but they seem susceptible to damage, wheel well filler trim pieces and my 10" side skirt extensions.
So far, I've found stated numbers of .25% efficiency increase with commercially available wheel covers for the rear. If my truck seems to average 8 mpg loaded, that doesn't seem enough for what they cost. Diy in process
Sorry I haven't been updating, although I have been at it. See updated photos.
My latest idea is to build a quick attach trailer tail. That's what the sketch with the measurements is for. I believe most of the trailers will have hinges in the same place so I'm considering a mount to them.
I thought about wheel covers for them as well but I'm sure I would forget them and the first time I have to drive back to get them it would negate any savings I may have from utilizing them.
ID:	32890   Click image for larger version
ID:	33912   Click image for larger version
ID:	33913   Click image for larger version
The Following 2 Users Say Thank You to Bigrigdave For This Useful Post:
Piwoslaw (09-22-2022), redpoint5 (09-21-2022)
Old 09-21-2022, 03:27 PM   #2 (permalink)
90 day: 29.78 mpg (US)
Man, I'd get pretty crazy AB testing if I got to pocket the fuel savings.
Guess you won't be going in this direction
Welcome to the forum.
Old 09-21-2022, 04:08 PM   #3 (permalink)
Welcome.
Do you know how to search the forum? It goes pretty deep.
Do you control the trailer, or are they rotated out? Here's something that relates to your use case:
C4Evermore (10-08-2022), Piwoslaw (09-22-2022)
Old 09-21-2022, 05:09 PM   #4 (permalink)
Red, unfortunately I'm not a scientist, I'm not cool enough because I have a plastic bumper and a robot shifting gears for me
Free beard I've been lurking for 8-10 years. I'm pretty familiar with site functions thanks. Unfortunately I can have the same trailer for a few days or even weeks but the hope is to drop and hook at every stop. I have a sliding fifth wheel which I was hoping to slide all the way forward but weights do not permit.
The Following User Says Thank You to Bigrigdave For This Useful Post:
freebeard (09-21-2022)
Old 09-21-2022, 05:18 PM   #5 (permalink)
All of the trailers have skirts and super single tires, some have 4 sided trailer tails, some have two sides but they're skirt always broken. The new trailers seem to have a two inch treatment along the lower middle of the door and a5 inch spoiler along the top and sides. I'll try to get some photos
ID:	33921   Click image for larger version
Old 09-21-2022, 05:20 PM   #6 (permalink)
Got it. Lurkers are important.
I don't care enough to search but there were wheel disks that expand like a crochet hoop to grip the wheel. Maybe they could be moved from one trailer to the next.
Bigrigdave (09-21-2022)
Old 09-24-2022, 05:17 PM   #7 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Probably an old hat to you, but Vekke designed smooth hubcaps for trucks/trailers some 11 years ago.
this is his thread: https://ecomodder.com/forum/showthre...cks-16478.html
and these YouTube videos seem to be most informative:
Covers are made of 3mm ABS sheet, iirc. The design is pretty straighforward, so you should be able to duplicate it, unless you are hopeless with jigsaw. I would try it for sure, if I were in youe shoes. smooth hubcaps are how much? 3 %?
Last edited by seifrob; 09-24-2022 at 06:19 PM.. Reason: some minor grammar and rephrasing
The Following 3 Users Say Thank You to seifrob For This Useful Post:
aerohead (09-26-2022), BamZipPow (03-18-2023), freebeard (09-24-2022)
Old 09-24-2022, 06:17 PM   #8 (permalink)
Not the same one [IIRC] but just as good.
Old 09-25-2022, 05:59 AM   #9 (permalink)
A good tire pressure gauge and a long enough air hose to reach the trailer wheels. Properly inflated tires make a big difference when hauling heavy.
Oh, and a scangauge.
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
Old 09-26-2022, 11:30 AM   #10 (permalink)
Seifrob, thank you for the link and videos. Looks like I'm going to buy a jig saw.
Redneck, I have a gauge. I need to buy a hose and adapter.
Thanks for the ideas folks, keep them coming.
I'm looking at extending the side fairings and an air Dam/splitter.
