Old 01-24-2010, 06:32 PM   #21 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
you and your welder might get along but i would stay away from a metal underbody
theyre really bad ass to look at, but it will weigh 5-10x that of a coroplast one
and the caprice/impala is heavy enough
ps: weight reduction (but you knew this already)
Past Present Future?
Old 01-24-2010, 07:08 PM   #22 (permalink)
tunedbytad's Avatar
Johnny 5 - '96 Chevrolet Impala SS Autocross Domination!
Caprice - '96 Chevrolet Caprice * Daily Driver * 9C1 retired cop car
90 day: 16.48 mpg (US)
I mentioned the welder in terms of moving the exhaust out of the way for the coroplast
NotoriouSS Tad < Professional EFI Tuner >
96' Caprice 9C1 - Retired Cop Car Daily Driver *!eco mod V8 project car!*
96' ImpalaSS - Johhny 5 - 7.9 @ 89 1.73 60'
67' El Camino - Rosie - 7.9 @ 86.5 1.77 60'
Old 01-25-2010, 03:28 AM   #23 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
On my truck, I dropped the air dam 6.5" lower and bumped the bottom lip forward about 3". Installed a lower pan fer that so it's pretty smooth from there. Also, I put in some front tire air blocks...4" clearance from the ground. Just installed a 4x8 luan panel fer my belly pan. Installed some side skirts with about a 4-5" clearance from the ground. Original clearance was about 13". Working on buttoning up the rest of the bottom to the side skirts and to the rear as well as in between the front air dam and the front crossbar.
My average winter mileage is better than my average summer mileage so far...
Lower belly pan build, lowered air dam build...
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
Rokeby (01-25-2010), tunedbytad (01-25-2010)
Old 01-25-2010, 05:08 PM   #24 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
one of the few indications increasing ground clearence is good for fe can be seen on the bristol figheter website
Bristol Cars - Homepage
(bottom left)
a very good looking car, that's not all that new, but it seems to be born from engineering that puts function before form, and thereby achieves a very attractive form!
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 01-25-2010, 06:05 PM   #25 (permalink)
tunedbytad's Avatar
You presented three options. Any of them, incorrectly executed, can actually degrade aero/fe/performance. Any of them, correctly executed, can improve things by, oh, up to 10%? None of them will be magic and, say, double fe or anything. All of them, correctly or incorrectly executed, can be thought to have about the same potential effectiveness. That being the case, how can one be selected as "the answer"?
Like I said from the get-go.
For a guy that knows everything
You have said a whole lot of nothing in this thread.
Old 01-25-2010, 06:50 PM   #26 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I believe that yer gonna just have to try them out and see what's gonna work fer you and what tools you have to determine if it's working fer yer project or not. Determining if it's working right is probably gonna be one of the hardest things to do...you'll just have to persevere...
Old 01-25-2010, 07:06 PM   #27 (permalink)
tunedbytad's Avatar
I have test and datalogging equipment.
that should serve me well.
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
