Old 05-03-2023, 07:58 AM   #21 (permalink)
So on a tapered cylinder like an antenna, would I just use the average diameter?
Old 05-03-2023, 09:10 AM   #22 (permalink)
How about a flat foil bow tie dipole? Or even better: inside the vehicle attached to the window?
Old 05-03-2023, 04:25 PM   #23 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Correct. I'd just measure the middle if it looks like the taper is the same down the whole whip.
Dipoles tend to be a half a wavelenghth instead of a quarter like with a vertical monopole ground plane antenna. So an 8.5 ft antenna now becomes a 17ft antenna. You'd need a prettly long window to put that on.
Old 05-03-2023, 08:02 PM   #24 (permalink)
A quarter wave on a vehicle actually has a half wave dipole, the vehicle is the other quarter wave. It's not perfect but that's the general idea.
The Following User Says Thank You to ai4kk For This Useful Post:
Isaac Zachary (05-03-2023)
