View Poll Results: AMERICANS: Would you buy a 125cc motorcycle for the street?
Yes! 37 41.11%
Hell no! 22 24.44%
Yes, but only at the right price. 31 34.44%
Voters: 90. You may not vote on this poll
Old 12-11-2024, 12:28 PM   #561 (permalink)
Rebound, not so much if it is different from mass dampening. Take a small rock, hit it sideways with a hammer, it moves a bunch if it doesn't shatter. Big rock doesn't move as far, less chance of shatter. Ever notice the off road racers now have extra large shock absorbers with side oil tanks and heat sinks?
LA freeways were like riding on a dirt road: every 8 ft when a pavement section ended there was a small height difference. My 450cc scrambler would jump, the harleys suspension sucked that all up and all you get was a small quivering.
Old 12-11-2024, 03:39 PM   #562 (permalink)
Trophy trucks weigh as much as two sedans.
What I found interesting was the reason they fly so well has to do with the angle between the rear tire contact patch and the pivot point of the trailing arm (really a beam), which is four feet long. The more acute the angle the better.
The shocks are also more complex than I'd known, with shock cooling reservoirs and bypass tubes.
Old 12-19-2024, 12:05 AM   #563 (permalink)
