Old 09-19-2023, 08:21 PM   #21 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Just a quick update. The diesel chevette to Pontiac sunbird is a little bit on the back burner right now. Currently in the process of swapping Honda CRX HF manual transmission into a SI engined CRX both same year cars 1987. I wanted to do away with the carburetor base gasket issues and all those numerous vacuum lines, so I'm curious to see what kind of mileage I can get with the HF trans but enjoying the more powerful SI engine? Time will tell.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
The Following User Says Thank You to larrybuck For This Useful Post:
freebeard (09-19-2023)
