Old 09-19-2023, 08:21 PM   #21 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Just a quick update. The diesel chevette to Pontiac sunbird is a little bit on the back burner right now. Currently in the process of swapping Honda CRX HF manual transmission into a SI engined CRX both same year cars 1987. I wanted to do away with the carburetor base gasket issues and all those numerous vacuum lines, so I'm curious to see what kind of mileage I can get with the HF trans but enjoying the more powerful SI engine? Time will tell.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
The Following User Says Thank You to larrybuck For This Useful Post:
freebeard (09-19-2023)
