01-01-2013, 12:23 PM
#141 (permalink)
I checked today, bent the pushrod around a bunch and the JB weld seems to be holding quite well. Better than I expected for sure. Now to get it hooked up to the actuator...
01-01-2013, 07:12 PM
#142 (permalink)
Red Light Avoider
Originally Posted by Daox
I worked on the grill block again last night. Its really starting to get near to its end form.
Here is a shot of the actual pushrods I used. I picked them up at a local hobby store. They're made for radio control airplanes. By the time I had sanded mine down those ridges were completely gone on the grey pieces. I only sanded it down in the area of the bend.
Hey Daox, speaking as a model airplane modeller I wanted to make a quick mention about the pushrods you chose. They are known for expanding and contracting with temperature changes and can mess with the trim settings on your model. Your use of such a short run should minimize this tendency though. Great project!
The Following User Says Thank You to pletby For This Useful Post:
01-08-2013, 05:52 AM
#143 (permalink)
Hi Daox, any news? Any tests? Photos?
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
01-08-2013, 07:59 AM
#144 (permalink)
None yet. Its in the plans, but just haven't had time for it quite yet.
01-08-2013, 08:08 AM
#145 (permalink)
So I'll still keep my fingers crossed
01-09-2013, 01:01 PM
#146 (permalink)
Very nice work!
01-09-2013, 01:06 PM
#147 (permalink)
Thalmaturge
A simpler version for those of us with mechanical knowhow but no computer knowledge would be this:
German Supply - Parts for VolkswagenŽ Cars - Home
Originally used with a pushrod or control cable and vent flaps in air-cooled VWs, available for opening at 65-70C or 85-90C.
Sam
The Following 6 Users Say Thank You to samwichse For This Useful Post:
01-09-2013, 08:46 PM
#148 (permalink)
I don't know how this didnt make it on the wiki before, but its on there now.
Grill block partial or full - EcoModder
01-10-2013, 10:30 AM
#149 (permalink)
starting with a brick
subscribed with a soda.
01-21-2013, 11:38 AM
#150 (permalink)
Simtronic
Great idea, very similar to mine, I was going down the simple route of no electronics just a heating thermostat bolted to radiator operating central locking actuator when the temperature exceeds 80 degrees just those two components and a fused supply from ignition on circuit. I guess I should also wire a manual override switch in the unlikely event of the thermostat failing
