Old 06-06-2008, 01:46 AM   #11 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
started the project..
1" schedule 40 PVC piping
heat gun action..
trial fitted before I hit it with the Red Hot Blue Glue
I'll have a little door in the front to access the front jack crank handle..
but It'll be hidden behind the V nose
Old 06-06-2008, 01:57 AM   #12 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
I know I'm a bit late to the party, but going by what I've read up on aerodnyamics, wouldnt a round (semi circle) front be a lot better than the splitter shape?
Still an improvement with the splitter. Now you're stabbing instead of sledgehammering the air.
Old 06-06-2008, 02:42 AM   #13 (permalink)
EcoModding Minded
Chris D.'s Avatar
I donno, your probably right, but this design was simple and cost effective..
I figured out my plan of attack and its only temporary anyways..
Old 06-06-2008, 10:34 AM   #14 (permalink)
An elliptical nose would be optimum, but what you have is just fine behind the truck.
Regarding bending the PVC pipe: Consider stuffing the pipe with dry sand, then heat it and bend around a mandrel. The sand will keep it from collapsing or buckling during the bend. You don't need to stuff the whole pipe, just the section to be bent, +/- ~10" either side of the bend point. Use a cork or similar stopper in the pipe to keep the sand in proper place.
Another idea would be to use longerons made of spruce strips, ripped into thickness about like a yardstick. This like the inner railing of rowboats at the gunwales, with spacers between inner and outer strips. A couple of 2X4s ripped lengthwise on a table saw into ~1/4" thickness, would do the trick and be cheap and durable. You could use some of that 3M foam adhesive construction tape to hold the skin to the longerons.
Old 06-06-2008, 12:25 PM   #15 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Progress is looking good so far
Old 06-06-2008, 02:59 PM   #16 (permalink)
EcoModding Minded
Chris D.'s Avatar
wow, you LOVE doing things the hard way
This is just temporary, its use is for one time only..
The trailer will be sold once I reach my destionation..
Old 06-06-2008, 04:19 PM   #17 (permalink)
Ex-lurker
Must be one of those "there is no such thing as over-engineering" types
Old 06-06-2008, 04:20 PM   #18 (permalink)
EcoModding Minded
Chris D.'s Avatar
what you see is a little over an hours worth of work,
took a break and went out for a late dinner, came back to it..
Old 06-06-2008, 05:05 PM   #19 (permalink)
EcoModding Seige Tank
digitaldissent's Avatar
yarii - '07 Toyota Yaris 4dr (auto)
90 day: 41.37 mpg (US)
Bullet Bill - '07 Toyota Yaris 2dr hatch
90 day: 36.19 mpg (US)
quick and easy might just be Ok for a onetime use, my question would be where are you moving too?
I am not trying to save the planet, just trying to hurt it a little less
Yaris build thread
what is... http://en.wikipedia.org/wiki/COINTELPRO
Old 06-06-2008, 05:42 PM   #20 (permalink)
EcoModding Minded
Chris D.'s Avatar
Moving to Minnesota, California's getting too ridiculous..
The Following User Says Thank You to Chris D. For This Useful Post:
HHOTDI (12-14-2012)
Teardrop trailer campers bennelson Aerodynamics 41 05-16-2024 03:57 AM
MetroMPG.com: Electric pusher trailer MetroMPG Fossil Fuel Free 30 04-23-2015 03:24 PM
How my home-built bicycle trailer lowers my MPG MetroMPG Alternative Transportation 17 03-30-2012 07:15 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
Cap vs Trailer: Trailer wins! bennelson Aerodynamics 10 05-08-2008 10:08 AM
