Old 02-22-2011, 07:35 PM   #101 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by some_other_dave View Post
There are other AT-equipped vehicles that you can coast with the engine off without destroying the trans. The key words to look for in the owner's manual are "flat towing". If the car can safely be towed with all four wheels on the ground, then it is safe to coast with the engine off. If it cannot be towed with the drive wheels on the ground, you're taking chances if you do engine-off coasting.
-soD
True, i didn't even think about that, though the location of the pump could be the reasoning in those cases, checking the manual would be a good way to know for sure
Old 09-07-2011, 05:23 AM   #102 (permalink)
Crawrolla - '11 Toyota Corolla S
Hi everyone,
I'm new on the this site and I'm intrigued by this topic. Before I purchased my Toyota, I was looking at the Hyundai's. I was wondering how they were able to generate more horsepower and better fuel economy. I think the culprit is they have a "smart alternator". Its the same methedology you guys are trying to accomplish.
I have less than 5 post so I'm unable to attach links or pics. Google Hyundai Smart Alternator and a lot of articles will show. I couldn't whether its controlled at the alternator or a relay.
Old 10-05-2011, 04:32 PM   #103 (permalink)
I think that it would be much simpler to make a mechanism to enable / disable alternator manualy from a button inside the car..when battery goes empty, you enable the alternator, until it fills up
Old 10-06-2011, 04:15 PM   #104 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Ah, it would be simpler, but the point of this thread is how to automate the process. Why? Because the driver doesn't always remember to pay attention to the battery voltage, or the car may be borrowed by someone who doesn't know (or doesn't want to know) about any buttons that need to be pressed.
Old 12-06-2011, 09:59 AM   #105 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I've read whole thread and have few ideas. First checking voltage to check if battery is drained it's great but to check what's the status during charge cycle requires to disconnect battery from the power source. But there's slightly different thing that can be done. You can measure the charging current and if it will drop below specified value you can turn off your alternator.
And another thought just to turn on alternator during engine breaking, it can be done easily with a preasure switch since during engine breaking mainfold pressure hits the lovest values. Isn't it?
I think even if the FE % gain is small it's worth to think of because every bit counts.
For sure I won't delete alternator in my Previa, because this car is used mostly for longer trips. And to carry deep cycle baterries that will last for 1000+ kilometers will kill my FE anyway But again if we could automate the process of charging battery I think I would go for it. I'll try to find out if my alternator can be easily switched off and I'll try to figure it out how to automate this process in my car.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 12-08-2011, 10:35 AM   #106 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
All new BMW´s has it, so it is a good idea!
Originally Posted by tjts1 View Post
All new BMWs have this.
Green Car Congress: BMW Introduces Intelligent Alternator Control with Regenerative Braking; Reduces Fuel Consumption by About 4%
Pair it with a deep cycle battery and you have yourself a winner.
I agree !
Go for it and share with us all.
Oldbeaver
Mercedes 300 D turbo 1993
Old 12-08-2011, 10:47 PM   #107 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
my idea would be to modify a smart battery tender. it already sees the battery and turns the charger on and off as needed. just need to find a way to put a relay in it big enough for an alternator relay.
altering this might be promising
http://www.electronicsforu.com/elect...tor.pdf&title=
Old 12-17-2011, 11:07 PM   #108 (permalink)
ok I talked to an E tech and he came up with we can build a circuit that will close a relay once a lower level is hit. the only issue is that once the alternator kicks in the upper levels will trip and then the whole system will just ping pong. he said the only way is for some type of logic to control it.
Basically he said that what will happen is taht the thing will trip at a low level then by programming. the logic will start a count down. and at 0 the logic will trip back on too the battery. if the certain battery level is not right the relay will trip back and the count down will start again.
looks likes its arduino time
Old 12-18-2011, 11:53 AM   #109 (permalink)
Arduino control for Alternator
It looks the same to me.
Even a very simple logic with Arduino will be a big step forward, as this will allow further improvement later. There are small arduinos that will be excellent for the final circuit.
Please do work on that and keep us all informed.
Oldbeaver
Old 12-18-2011, 01:00 PM   #110 (permalink)
hook a switch to the throttle. When throttle is closed, field windings are energized.
with the same switch, turn off the power to the fuel injectors.
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 10:02 AM
