Old 01-20-2010, 01:33 AM   #91 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
I just need to monitor this thread. I had not considered this idea...it would have been ideal on my old VW Rabbit diesel.
Old 01-20-2010, 11:45 AM   #92 (permalink)
Ecomodder in Training
Rainh2o's Avatar
Green Machine - '96 Ford Contour GL
90 day: 34.9 mpg (US)
I thought thats what regulator did in a car, was charge the battery and respond to loads
Old 03-05-2010, 12:07 PM   #93 (permalink)
Grocery getter - '99 mazda protege DX
Last 3: 38.1 mpg (US)
CRX Otterbox - '91 Honda CRX HF
Last 3: 51.07 mpg (US)
Send a message via AIM to HeadlessNorseman
some food for thought here may be that some ECU/fuel injection/ignition systems work crapily with under 14v. On one of my cars(i believe a toyota supra 3.0 na 5 speed) i took all the accesory belts off to see if i gained any power and the car did not run well at all on only 12 volts. Many misfires and less overall power above 3-4000 rpms. It may be fine at the lower rpms needed for cruising but someone may have more knowledge on this
Old 04-29-2010, 06:02 AM   #94 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Crosslinking from a new thread:
Honda Alternator with ELD
Old 09-13-2010, 10:18 PM   #95 (permalink)
Versa - '12 Nissan Versa Hatchback S
90 day: 39.65 mpg (US)
Did anyone ever get this figured out? It appeared AX was close, but had a problem with the feedback loop built into the alternator. I was thinking about doing something similar, but I was unaware of the feedback loop residing within the regulator. There is always the option of going with an external regulator and removing the internal one. This woud allow for more fine tuning of the circuits. I will keep looking at things, especially if I can get a spare alternator and some wiring schematics.
Old 09-14-2010, 07:16 AM   #96 (permalink)
I do this manually (havent read this thread in a while). I turn my alternator back on if I'm going down a hill. I hold my kill switch and open the throttle fully. You really don't slow down very fast doing it this way, and it works fine. I suppose I could automate it by hooking up my alternator field wire to a relay triggered by the brakes. I haven't done it since I don't really use the brakes that much.
Old 02-08-2011, 01:25 PM   #97 (permalink)
Originally Posted by AXMonster View Post
Shouldn't be as the charging wouldn't occur without the engine turning
not all P&G is done with the engine off! hard to start engines are sometimes best left running
Old 02-08-2011, 01:34 PM   #98 (permalink)
97 Eclipse Spyder
Originally Posted by s2man View Post
My thinking too. I'd put the microswitch on the throttle. 0 throttle = charge. Besides charging while decelerating, that would also charge during my neutral coasts on the hills where the stupid a/t is pushing the rpm's up around 1100. I'd also add a parallel switch so you can energize at will (eg the battery is low, headlights or fan on, etc).
only thing about attaching to throttle is for a manual shift, your fully releasing throttle quite a bit during shifting, and it would kick the alternator in for like a second at a time jolting in and out of action. idk if thats good for the alternator but pretty sure the ecu would freak out or you'd blow something...
thats why im only having it cut on when either:
1. brake lights are on --->relay
2. Headlights are on------>same relay wire
3. manual switch -------->same relay wire, spliced in.
either one, some, or all, of the three will engage alternator, through the same relay.
the headlight wire is convenient so you will have a constant charge coming on under load like at night.
Old 02-13-2011, 06:44 PM   #99 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
or AT equipped cars that will kill the tranny if the engine isn't running. no running engine = no ATF flow
EDIT: unless you have an old Chrysler 300 or similar with the pump on the tranny output shaft
Old 02-14-2011, 02:47 PM   #100 (permalink)
There are other AT-equipped vehicles that you can coast with the engine off without destroying the trans. The key words to look for in the owner's manual are "flat towing". If the car can safely be towed with all four wheels on the ground, then it is safe to coast with the engine off. If it cannot be towed with the drive wheels on the ground, you're taking chances if you do engine-off coasting.
-soD
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 10:02 AM
