Old 02-15-2015, 06:47 PM   #11 (permalink)
John
C-REX's Avatar
C-REX - '84 Honda CRX
90 day: 48.16 mpg (US)
Originally Posted by nemo View Post
Some food for thought. Areohead post about this picture in several places. Might try a search.
I will see what I can dig up, thanks
Old 02-15-2015, 07:53 PM   #12 (permalink)
Nice save
Old 02-15-2015, 08:04 PM   #13 (permalink)
Wonder how this matches up with "the template"
Old 02-15-2015, 10:49 PM   #14 (permalink)
John
C-REX's Avatar
Sorry for the pic of my screen but it was the only way I could seem to keep them together
ID:	17023   Click image for larger version
ID:	17024   Click image for larger version
The Following User Says Thank You to C-REX For This Useful Post:
deejaaa (03-21-2015)
Old 02-17-2015, 01:20 PM   #15 (permalink)
Apart from the aeromods, what are the other approaches you're considering to increase the efficiency of your car?
Old 02-17-2015, 02:18 PM   #16 (permalink)
John
C-REX's Avatar
I have been reading up on water injection and think I might give that a try. the car has little power and really dose not like hills. I would like to find some sort of scan gauge as well but everything I have found is for 96 and newer.
Old 02-17-2015, 04:45 PM   #17 (permalink)
Champagne - '13 Chevy Cruze 1LT
90 day: 33.35 mpg (US)
I think you may have to use a MPGuino for that one since it is pre-OBDII. Here is the link for the MPGuino
MPGuino - EcoModder
Old 02-17-2015, 04:51 PM   #18 (permalink)
John
C-REX's Avatar
"It still works for just about any car with fuel injection, but for cars built before 1996, there is no OBD-II option. "
My car is carbureted, will it still work?
every thing I have seen says fuel injected
Old 02-17-2015, 09:50 PM   #19 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Unless there is some sort of air intake sensor or some way to meter air or fuel into the engine, it won't work sadly.
Convert it to fuel injection or maybe an engine swap is a good target. I don't know much about Hondas, but Toyotas have a semi standard bolt pattern on their transmissions, so engine swaps are mechanically simple, just the electronics that can be the fun part.
Old 02-18-2015, 08:40 PM   #20 (permalink)
90 day: 40.51 mpg (US)
The template included with the tool is actually not quite right. It's a bit too shallow.
My recommendation is to use this tool:
Image Overlay Utility
And this template:
Then, when you have them overlayed, hit the "printscreen" key on your keyboard, open MSPaint, and paste, and it should paste a shot of your screen.
