Old 01-15-2018, 01:35 AM   #21 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I thought I picked up 1-3mpg from my Ps delete. Love my CX/VX trans too. But I am not sure I would swap the HX trans for a VX trans because of how it will effwct when and in what gear at what speed you can attain lean burn. The super-tall VX gearing works against the HX design at our normal speeds.
Old 01-15-2018, 05:06 AM   #22 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
This exactly. I just couldn't get into lean burn at all. And stop and go just... Awful. The BSFC was different on that engine was higher up in the rpm range as well. The car weighed 15% more, etc etc. I love the HX trans. It's gearing is just so perfect IMO.
Old 01-15-2018, 05:21 AM   #23 (permalink)
DSMHondaGuy's Avatar
Sipper - '98 Honda Civic HX
90 day: 40.14 mpg (US)
Originally Posted by oldtamiyaphile View Post
I gained 1mpg by removing the PS belt on a similar car. Swapping to a manual rack means you'll get a different ratio (slower) which you may or may not want. It's very easy to just pull the belt and give it a go.
Ordinarily doing so results in a stiffer steering feel than anything else. There is a way to modify it that makes it much easier, Miata guys figured it out years ago.
Right now I'm most interested in low investment high return modifications though.
Old 01-15-2018, 05:34 AM   #24 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I always thought it would feel like crap and bought a MR2 pump to swap out the mech pump, but I thought I'd try just taking the belt off first. The steering feels better than the non assisted Suzuki I had, and I prefer the faster ratio. The MR2 pump is huge and heavy so I don't expect I'll ever use it. Ideally you'd gut the rack properly, but it's not necessary.
For $0 and ten minutes, the ROI is pretty good.
Old 01-15-2018, 05:56 AM   #25 (permalink)
Once I start doing a few aero mods and stripping some weight out of the car I may try it out.
Old 01-19-2018, 04:50 PM   #26 (permalink)
I see that you have a garage entry, but you did not link a build thread. You do not copy and paste the address, just the five digits on the end, so if you wanted to link this one, you paste 36044.
Old 01-19-2018, 05:18 PM   #27 (permalink)
Thank you.
Old 01-24-2018, 08:18 AM   #28 (permalink)
Tire pressure raised to 43psi has yielded 41.48mpg. 378.8 miles out of 9.133 gallons I will say there were a couple drives to and from work where increased air temps sure didn't hurt either. But then there were a couple trips to the local grocery store too so *shrug* Target speed has largely stayed at 55mph. The exception being going down hill I'd leave the throttle where it was and pickup speed to carry into the next hill, unless there wasn't one then I'd lift to maintain speed. Most shifting has stayed between 2500-2750rpm staying in as high a year as I can and getting there as soon as I can realistically for the given scenario of the moment.
I have collected 1 or two pieces of sizeable scrap sheet metal (aluminum) that's thin. So I'll start on aero soon. First order of business will be to repair that part under the bumper, and adjust the drivers side fender as it's high for some reason.
So long as temperatures are reasonable this weekend I'll probably pull it into the shop and get under it and start developing a plan for how I'm going to attach the under tray and where.
Eta: I did for sure notice lean burn engaging the other day on the drive home, I felt a weird reduction in power as if someone suddenly retarded the ignition timing a lot. So lean burn is working.
The Following User Says Thank You to DSMHondaGuy For This Useful Post:
RedDevil (02-02-2018)
Old 01-24-2018, 09:07 AM   #29 (permalink)
Congrats on hitting your first goal, and in winter no less.
Old 01-24-2018, 10:55 AM   #30 (permalink)
Thank you, my next goal is to surpass the original (optimistic) EPA rating before they were forced to change how cars were rated. So better than 44mpg.
