04-14-2016, 05:26 AM
BEST + CORRECT Aerodynamic FRONT
The Following User Says Thank You to slipknotsv For This Useful Post:
04-14-2016, 10:57 AM
good...........
04-14-2016, 12:17 PM
You are focusing on the loft line (profile) and ignoring the wheelwells.
In turns the top of a tire doesn't move in/out as much as the middle of the wheel/tire. A uniform radius from the resting center of the wheel is sub-optimal.
04-15-2016, 04:28 PM
that it's nose is nothing remarkable,although it does have a complete boat-tailed rear.
04-15-2016, 07:48 PM
Or maybe it's a bluff nose with a low stagnation point, and a rear end that is too fast—intentionally, to improve cooling air intake—but too fast none-the-less. The narrowed front axle is good prep for front wheel skirts.
What a corrected Beetle body might look like.
04-16-2016, 01:17 PM
nose
here is some data from R.G.S.White at MIRA,1969,
look at plan and elevation
if you take all of his best of each category you get Cd 0.245 (in 1969)
here's some windshield data from FIAT
cowl height
and nose
front lift
from Fachsenfeld (KAMM)
Hoerner
Eiffel
Eiffel
Walter Lay,1933
04-16-2016, 04:06 PM
Big thanks Aerohead
04-16-2016, 05:04 PM
04-16-2016, 06:25 PM
#9 (permalink)
aerohead -- So I try to get by with a rerun, and you throw out a whole bunch of new stuff.  I think I'd seen only the last two before.
The first one is fun! For the Beetle, I get A-2 B-2 C-1 D-1 E-7 F-1 G-6 H-4. Is there a secret decoder key?
Frank Lee -- It's a setup. You want us to have to admit it's that first one.  I'm going to go with:
It's all about the fineness ratio.
04-16-2016, 06:29 PM
#10 (permalink)
Fineness ratio? I thought it was about fuselage length.
