05-11-2017, 10:28 AM
#21 (permalink)
Focused on MPG
May I suggest using an electric a/c compressor off of a hybrid
Maybe a group 31 deep cycle battery or 2 to supplement the lack of alternator
Maybe a couple of those electric motors made for bicycles to run all the time to charge batteries
And a possible conversion to manual steering off an old 70's jeep
Staying Focus'd on MPG
05-11-2017, 12:45 PM
#22 (permalink)
From what I have been abe to find the hybrid AC compressors run at very high voltage.
They run off pack voltage, which depending on the hybrid could be as high as 330v dc.
05-11-2017, 03:48 PM
#23 (permalink)
Focused on MPG
Hmm, that is probably correct, I didn't research before responding to the thread
05-11-2017, 04:29 PM
#24 (permalink)
Putting lean burn an an OBDII vehicle would be a lot easier and give more improvement than trying to create some kind of electro mechanical regeneration brake system from the ground up.
I really don't think you're understanding the concept of this thread.
05-11-2017, 06:12 PM
#25 (permalink)
What's the plan to add regeneration braking?
Which I think is cool.
If you're trying to save fuel.
What did I miss?
Since I have done both I'm just letting you know the accessory delete will disappoint and I will leave it at that.
05-11-2017, 07:53 PM
#26 (permalink)
Originally Posted by OP
Best way to add regenerative braking to a Jeep?
http://ecomodder.com/forum/showthrea...r-35003-2.html
[added verbiage to encourage you to click the link]
05-11-2017, 08:40 PM
#27 (permalink)
What did I miss?
Not a single one of your replies has to do with the question asked about regenerative braking. I did not ask you or anyone else how much fuel removing the belt would save, and mostly I do not appreciate your argumentative responses.
As Ecky pointed out so well, I don't need a reason to do what I'm doing, other than I want to.
05-11-2017, 11:51 PM
#28 (permalink)
That works for me.
Now how to do it?
05-12-2017, 02:02 AM
#29 (permalink)
Mostly correct. The most prolific electric compressor (from the Prius) runs on 200VAC. Yes. AC - 3 phase
05-12-2017, 09:43 AM
#30 (permalink)
Would that be single phase or 3 phase?
