Old 03-28-2010, 02:50 PM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
Blown fuse IDK what its for/already googled, no results
Ok I was checking all my fuses for any blown, there is one blown but IDK what its for and dont have another "10" fuse to replace it with...
The description on the map says
" B/U LP Switch
EBL SW Clutch Switch"
Is that back up lamp switch? I have no idea haha
Can anyone decode this for me?
Old 03-28-2010, 02:58 PM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
back up lamps and EBL(?) and clutch start interlock (if applicable).
Turn your key on, set the parking brake, and put your car in reverse (do not start it). See if your reverse lamps are on.
The Following User Says Thank You to Christ For This Useful Post:
RandomFact314 (03-28-2010)
Old 03-28-2010, 03:04 PM   #3 (permalink)
90 day: 34 mpg (US)
Yeah no back up lights... Now to figure out what EBL is so I know what else is not working
Old 03-28-2010, 03:05 PM   #4 (permalink)
Electronic (something? Brake?) lockout?
Old 03-28-2010, 03:05 PM   #5 (permalink)
90 day: 34 mpg (US)
EBL- Emergency Brake Light???????? Possibly?
Old 03-28-2010, 03:07 PM   #6 (permalink)
Sure. Raise your parking brake and tell me if the light comes on.
Old 03-28-2010, 03:08 PM   #7 (permalink)
90 day: 34 mpg (US)
I also found this.... The fuse is fuse #7....:
the locks fuse is fuse #7, a 10 amp fuse.
Read more: I have a ''02 Dodge Neon that flashes the word - JustAnswer
Old 03-28-2010, 03:15 PM   #8 (permalink)
90 day: 34 mpg (US)
E-Brake light DOES come on when e-brake is up...
Old 03-28-2010, 03:19 PM   #9 (permalink)
90 day: 34 mpg (US)
I think I figured it out! Here:
Electric Back Light, it's the heated rear window, in glass terms a window is referred to as a light
----This sounds correct b/c my rear window defrost has been out for about a 1/2 year, which means I have not had back up lights for a 1/2 year OMG...
Found the info here: http://www.dodgetalk.com/forums/showthread.php?t=83091
Old 03-28-2010, 03:51 PM   #10 (permalink)
...beats walking...
...aren't unique acronyms unique?
