03-31-2013, 07:53 AM
#111 (permalink)
Kill switch update
One more thing regarding a kill switch in Berta. I needed to add 3 diodes to the setup because of electric noise (dirty power) that was messing up with my MPGuino
So actual diagrams are looking like below
Fuel cut off valve:
Starter:
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
03-31-2013, 01:08 PM
#112 (permalink)
Eco Sol
Originally Posted by AndrzejM
There's no difference at all. You just need to cut some signal to kill the engine spark or fuel or maybe some sensor for example Piwoslaw in his Svetlana is cutting the cam position sensor to kill the engine. Starter you need to connect the same way I did.
Great! Thanks for the info, the kill switches have been hard for me to wrap my head around because of how many different ways I have seen them done and on all sorts of different engine types. This may be my next project. Either that or interior mirrors, cause those exterior parachutes are jacking up my airflow
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
04-01-2013, 01:47 PM
#113 (permalink)
It's good to start with wiring diagrams of your car. Then you can decide if you should cut the fuel or spark to kill the engine.
04-01-2013, 02:53 PM
#114 (permalink)
aero guerrilla
Or cut the signal from one of the sensors. As Andrzej mentioned, my kill switch is on the crankshaft position sensor, since the lack of this signal tells the ECU to turn the engine off. Manually forcing a kill ( via fuel, injectors, or ignition) may cause some damage, and/or make the ECU throw a code, or even go into limp mode. Letting the ECU go through its own engine shutdown procedure seems to be safer in newer models, though also risks getting a code.
04-08-2013, 08:29 PM
#115 (permalink)
Awesome work!
I just bought a 318ti here in the US, so it's a 1.9L gasoline engine. I mainly bought it because I love the style of it, but I'm hoping to get myself up to 40MPG or so. First off is bringing my MPGuino back into play - that instrument cluster mount is awesome, it looks stock. I'm definitely putting mine in the same spot.
04-09-2013, 08:08 AM
#116 (permalink)
Thanks McTimson. And good luck with your 318ti, there's many things that you can do to improve her fuel efficiency.
04-17-2013, 05:02 AM
#117 (permalink)
Berta is ready for a trip to Prague
I'm in Prague and for now I have more than a half of a tank. MPGuino shows 26.2km/l (61.63 MPG US), not bad ;-)
04-17-2013, 10:18 AM
#118 (permalink)
aero guerrilla
Impressive  I would have painted the miniskirts so that they're not as visible. Watch out for rain
I see that you love your passenger side mirror too much to fold it
04-17-2013, 10:56 AM
#119 (permalink)
I don't mind rednecks to stare at Berta, so I haven't masked anything. But as you probably know it's just a temporary "solution" to test if I'll see any gain from it. We'll see on next fill-up at the pump
Regarding mirror I haven't folded it because of two reasons. First, my inside RW mirror is not working well because of curvature of the Berta's body. I have to find another solution for RW mirror.
Second, when I'll finish my kammback I won't be using internal RW mirror at all, because there won't be any glass/lexan panel. So If I want to know what will be improvement from it I need to use both mirrors for now. But I'm thinking of much smaller external mirrors, for both sides.
04-17-2013, 03:10 PM
#120 (permalink)
aero guerrilla
The attention I had in mind was from the law enforcement rednecks
Regarding mirror I haven't folded it because of two reasons. [...]
OK, that makes sense. I can't wait to see which mirrors you find, I'm thinking about something smaller to replace my passenger mirror.
