Old 02-10-2013, 04:42 PM   #101 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
6.5mpg in it...
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 02-11-2013, 05:16 AM   #102 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Kill switch continues
The plan is to combine kill switch and additional starter switch with one rocker on the shift knob.
So to kill the engine I have to connect it like that:
And to start it:
I bought the wires and relays so I'm ready. I'm hoping I'll publish pictures of the innstalation process soon.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 02-11-2013, 05:20 AM   #103 (permalink)
Team m8
That looks like a elegant solution!
One question though- are you sure the battery/starter is up to it?
I know all the BMW efficient Dynamics cars have heavy duty starters, due to the large increase in cycles they have to perform
Old 02-11-2013, 05:25 AM   #104 (permalink)
AndrzejM's Avatar
I'll try to bump start the engine during normal EOC cycle and starter will be used for full stop, so I'm sure it's up to the task.
Old 02-11-2013, 06:09 AM   #105 (permalink)
Team m8
Ideal
I know from experience that starter motors on BMW's are a pain to change
Old 02-12-2013, 02:56 AM   #106 (permalink)
AndrzejM's Avatar
Ideal
If you remove few things which stays in a way it's very easy, but if you want to remove just the starter it's a painful experience. Starter will come only at the right angle and there's no place to stick both hands there. But it can be done Anyway I'm not planning to destroy the starter
Old 03-28-2013, 03:39 PM   #107 (permalink)
Eco Sol
Shortie771's Avatar
8. Knob back in the car
So how does this switch work? is it "|" turns off the injectors, "o" will turn them back on and "||" will bump the starter? If so, that is exactly what I have been wanting to do with mine. I already have most of the parts just laying around in the garage.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 03-30-2013, 07:46 AM   #108 (permalink)
AndrzejM's Avatar
The switch works the way that if it's on "0" then both circuits are opened, rocking it to I or II positions is switching on two separate circuits. One for cutting off the engine - electrovalve on injection pump (diesel), second one starts the engine with a starter. if it's in "0" it works like a normal oem setup. I've used two relays one normally opened for a starter, second one is normally closed for feeding current to electrovalve. So when I press the button is switches relay from normally closed to open position and electrovalve cuts off the fuel.
It works great. I have to control over the engine with just my thumb.
Old 03-30-2013, 11:51 AM   #109 (permalink)
Eco Sol
Shortie771's Avatar
Very nicely done. I would like to do the same on my car. Would there be any differences since I don't have a diesel?
CR-Z Current Mods:
Max Sidewall PSI
Old 03-30-2013, 04:04 PM   #110 (permalink)
AndrzejM's Avatar
There's no difference at all. You just need to cut some signal to kill the engine spark or fuel or maybe some sensor for example Piwoslaw in his Svetlana is cutting the cam position sensor to kill the engine. Starter you need to connect the same way I did.
