07-23-2012, 11:02 AM
#31 (permalink)
Hydrogen > EV
Originally Posted by mcrews
I have to question this advise.
I have owned may different cars (automatics) and have NEVER rev'ed up when going back in gear.
The tourgue converter then has to compensate and that is BAD.
I had a 97 Ford Escort, and it did need extra throttle before going in gear or it would lurch more. I remebered it happening, and was thinking what car was it, yea, it has happened with an automatic with me. I mean, that was at highway speeds, 65+, but I think that what you guys were talking about.
07-23-2012, 09:56 PM
#32 (permalink)
Intermediate EcoDriver
Since you're a psychic medium, YOU should be able to tell US what kind of damage you could do to your transmission by coasting in neutral. I (for one) am completely unconvinced concerning your psychic ability. Why haven't you won the lottery every time?
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
07-24-2012, 12:39 AM
#33 (permalink)
I have never lost the lottery. Who is the psychic?
07-24-2012, 03:13 PM
#34 (permalink)
home of the odd vehicles
I had never lost the lottery either until I played for the first time last week, I guess I was psychic all these years, never again.
07-24-2012, 10:26 PM
#35 (permalink)
Look at the OP's profile. I'll crawl back under my rock, now.
The Following User Says Thank You to Mustang Dave For This Useful Post:
07-25-2012, 12:06 AM
#36 (permalink)
The transmission will be fine
I am not an expert on toyota's however I am an ASE certified master technician and a GM master technician and here is my two cents:
1- Automatic transmissions do not have a "neutral gear" when they are in neutral none of the clutches are applied and everything is basically freewheeling. what wears in an automatic transmissions is the clutches, and they only wear if they are slipping (ie low hydraulic apply pressure), or during the brief moment they slip as they they are applied, until they are fully applied and the assembly is now rotating at the same speed. the only wear you are doing to the transmission is the additional shifting, which is nothing to be too concerned about.
2- the manufacturer will not deny a warranty claim because you have been shifting into neutral. i have seen GM warranty transmissions that were physically broken in half from abuse. the vehicle data recorders that are on the vehicles give us a snapshot of up to 2 min of data when a dtc occurs, and it is a pretty limited amount of data we have.
3- as long as the engine is running, the transmission pump is providing lubrication. chrysler in particular does not run the pump in park, but all transmissions run the pump in neutral and will be lubricated.
In short, i wouldn't be afraid of damaging a transmission by putting it in neutral, no matter how new or old the car is. modern automatic transmissions are extremely robust and can handle a surprising amount of abuse. To put your mind at ease, I work primarily on oil field trucks that spend most of their time off-road and see more abuse than people can imagine, and it is surprising how few failures we see.
The Following 2 Users Say Thank You to jtlemon For This Useful Post:
08-08-2012, 12:35 PM
#37 (permalink)
High Mileage Lover
Brake Masters
Minutes after buying my first car someone pulled in front of me, I hit my brakes, and they squealed, so I went to Brake Masters, that advertised $99.88 for four wheels, in most cases. They came back and said that the brakes would be that price, but that I needed to replace all of these other things, and the total would be around $450. While I waited they told countless other customers exactly the same thing, so I had a bad experience with that chain.
Do you do all of your business there?
I just saw this question, sorry. I do tend to go to Brake Masters a lot. I've actually had a good experience with this one (and one in Los Angeles I used to go to). I don't trust hardly any service places, to be honest. I went to some indie one way out in the middle of nowhere for a transmission fluid flush and I don't think they ever did it...according to how dirty my fluid was not long after.
Atheria
I love my cute Fiat 500, Sophia!
08-08-2012, 12:45 PM
#38 (permalink)
High Mileage Lover
Thank you JTLEMON and to all of the mockers...GRRRR
Although, out of fear, I have switched back to not coasting in neutral, your response made me feel better, thank you. My boss did say though (but he's also not a mechanic...hahah) that although my automatic 2008 Scion's engine may be pumping some transmission fluid even in neutral, that it wouldn't pump out as much as really needed because the car would "think" it was stopped and not moving at 40-60 mph. Is that true?
And to all of the psychic mockers. I am the real deal, but I don't specialize in tuning into my car's transmission. And, psychics are not given things like winning lottery numbers because that is not the right use of our gifts. Also, when I am emotionally attached to the verdict (i.e. hoping to become a millionaire) I have a hard time getting clear information. My desire makes my logical mind get in the way. Warner Bros. tested me on camera and was willing to spend millions on a TV show in 2007, so you can ask them. If not for the stupid Fox Network, I'd be driving an Aston Martin right now...not that I don't love my Scion.
Atheria
08-09-2012, 08:18 AM
#39 (permalink)
Ah, good to hear from you. I was feeling unloved!
08-09-2012, 11:31 AM
#40 (permalink)
High Mileage Lover
Awwww.....don't be hurt. I love you boys! LOL
