Old 10-18-2019, 10:13 AM   #11 (permalink)
Kenny - '09 Kia Rio 1 GS
I have since added my car to the garage on the site
Yes you cannot I read the owners manual, key has to be in otherwise electric power is not supplied ��
The Following User Says Thank You to dude7691 For This Useful Post:
RedDevil (10-18-2019)
Old 10-18-2019, 10:36 AM   #12 (permalink)
Steering lock does NOT engage unless key is REMOVED from switch.
Unless this car is some sort of freak or possessed by satin the engine shuts off when you key off. DON'T go back to ACC. It's between OFF, ON, and START, that's IT.
Steering lock engages even when the key is in if it's on OFF. Only by moving it to ACC does the steering lock disengage.
The main headlights do not work when the car is in ACC, it supplies power to stuff like the radio, sidelights, dashboard lights e.t.c, but not the main headlights
You put the car into ON to put the headlights on, and naturally the engine starts up thus EOC is impossible
Old 10-18-2019, 09:11 PM   #13 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Why would it naturally start up? If you're still in gear, yes, but "run" isn't "start".
Transmission type Efficiency
Old 10-19-2019, 11:34 AM   #14 (permalink)
Computer control assumes you commanded start when you push the on button. Probably has an annoying system to bypass that.
Old 10-19-2019, 11:53 PM   #15 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Sometimes I'm glad to have a primitive car.
Nice numbers, and welcome to the site!
