Old 06-04-2013, 10:48 AM   #21 (permalink)
Originally Posted by botsapper View Post
Always intrigued by aftermarket Aeromotions moveable wing; active split rear wing contributing to left/right rear downforce bias, high-drag braking and top speed low-drag wing angles.
How cute! They used electric motors to replicate what the original 917 and one of the 908s did with linkages from the wings to the suspension.
-soD
Old 06-08-2013, 04:20 PM   #22 (permalink)
Epcot Car
Circa 1984,at GM's exhibit at Epcot Center,Orlando,Florida,they had a concept car which had an active diffuser which would lower to near-horizontal at a pre-programmed velocity,presumably when you were on the highway and ground clearance wasn't as much an issue.
This diffuser was designed specifically for improved MPG and they included an animation depicting the improved airflow.
Old 06-19-2013, 04:50 AM   #23 (permalink)
fabrio.'s Avatar
tigra AERO - '96 opel tigra
I remember these:
2005 Citroen C Sportlounge
2005 Citroen C-Sportlounge Concept Images, Information and History | Conceptcarz.com
and the Fioravanti Flair
1996 Fioravanti Flair - Studios
The Following User Says Thank You to fabrio. For This Useful Post:
NeilBlanchard (06-19-2013)
Old 06-19-2013, 05:31 AM   #24 (permalink)
Thanks! The Citroen C Sportlounge is exactly the car that I saw! Actually I didn't remember that it was only a concept. Now I'll read the articles the links you posted.
Grazie mille, fabrio... non mi sarebbe mai venuta in mente
Old 06-19-2013, 07:54 AM   #25 (permalink)
NHB
An example: Difflow Diffusers - Lotus Elise and Exige Flat Track Diffuser
This is an non-active aftermarket part on a Lotus Elise. I'd like to see "a med-low price car, a hatchback" with that stock. So I'll watch the thread.
Why you would like to have a diffuser like that under a hatchback?
Old 06-19-2013, 01:06 PM   #26 (permalink)
'See' not 'have'.
Originally Posted by LogicPro
It was probably a med-low price car, a hatchback if I'm not mistaken, which was launched 4 or 5 years ago more or less.
I actually like the Citroen C Sportlounge, except for the name.
Also Pagani Huayra have active air control flaps front and rear.by Jay Leno at 3:25->3:32 and 4:57->5:08.
Old 06-19-2013, 01:54 PM   #27 (permalink)
Either to accelerate the air going out the back, providing down-force, or just for looks.
-soD
Old 06-19-2013, 05:01 PM   #28 (permalink)
I thought it was a reasonable question. This suggests a diffuser would increase the drag on an hatchback:
But, yeah, I meant 'see' as in
Old 06-24-2013, 04:08 AM   #29 (permalink)
NHB
-soD
It doesn't help with aerodynamics. You won't see higher mpg or cornering speed.
active, aerodynamics, diffuser, spoiler
