04-16-2014, 05:52 PM
#31 (permalink)
Image search! Of course! I guess that welding your own frame and removing the center half makes sense, but the finished product does not have the seam.
I do not think there is any taper, as beautiful as that car is, I imagine that it would be obvious. I imagine that you would start the taper behind the doors, which would create a noticeable corner, unless you want to create a whole new body panel!
04-16-2014, 06:07 PM
#32 (permalink)
What? You thought I was some genius?
I have been looking further. Here's the owners website: http://www.bugwing.com/. It turns out he did all the work to promote a particular religious perspective, AKA proselytize. The link to construction details at http://www.digitalbiker.com/bugwing.htm hits a wall for me.
Here's two pictures of a front engine/rear drive trike:
I agree about the plan taper, but I'd start the pie-cut at the A-pillar instead of the B-pillar. It's narrower there and you'd only lose a little elbow room.
04-16-2014, 09:54 PM
#33 (permalink)
Front-engine in a Beetle body, even modded the hell out, is kinda weird.
04-17-2014, 12:31 AM
#34 (permalink)
Unblown flat-four in front with a bug-catcher; Studebaker cab back and Porsche 924 transaxle in back.
Blackjack Zero with front/front. 2CV-based car in the rear.
Motoguzzi V-twin in frontwheel drive.
The V-twin [probably] would fit in the front sheetmetal and bumper.
Edit: has anyone else noticed that skippo bumped this thread from 2012 and hasn't posted since.
04-17-2014, 06:46 AM
#36 (permalink)
It looks like the gearbox of the longitudinally-engined early FWD Volkswagens. Kinda off-topic, but I've already considered to fit a Harley-Davidson engine into a Dasher...
04-17-2014, 01:25 PM
#37 (permalink)
I am still here , I just find this thread on Google. Seem like the topic is wondering off where my interest. I am looking to build a 3 wheel diver high performance hybrid. That get very good mpg. Not just a reverse trike.
04-17-2014, 03:57 PM
#38 (permalink)
Would it be better to taper from the A-pillar or just have the A-B section narrower and rectangular?
04-17-2014, 04:04 PM
#39 (permalink)
skippo -- Somewhere along the line you registered on the site. Actually on 10-30-2012.
If you scroll to the top of this page you will see where it says "EcoModder Forum > Introductions > Car conversion to 3 wheels". If you click on Ecomodder Forums and pick some thing or other, like General Efficiency Discussion, or Hybrids, or DIY/How-to you will have possibly a more suitable result. Personally, I don't mind people bumping old threads but Introductions is an odd place to do it.
Xist -- the Beetle body is compound curved from the get-go. Template-wise the widest point wants to be at 30% of overall length.
04-18-2014, 08:35 AM
#40 (permalink)
Maybe you should start looking for either a wrecked BMW R-series motorcycle or a Can-Am Spyder to be the donor of the rear assembly and internal-combustion engine, while you could fit an electric drive at the front axle of your 3-wheeler if you choose a front-engined FWD car as the base.
