09-29-2012, 11:29 AM
#11 (permalink)
T-100 Road Warrior
A new OEM converter fer my T-100 lists around $1600 from the dealership. Online discounts drop it to about $800 not including shipping.
This is the technical paper I am basing my converter washing on...
http://www2.ucy.ac.cy/~chpgsc/arthra...%29%202030.pdf
On the other hand, there are a lot of cars with cats in California, big market, money to be made if your idea works.
Exactly...
After 30 minutes...
Residue at the bottom of the CatWasher...
Dark Aero-The world's first aerodynamic single wheel boat tail!
09-29-2012, 12:28 PM
#12 (permalink)
That paper has been reviewed, then published, looks like a decently thorough investigation of one failure mode of one Mazda catalytic converter.
Do you have any idea why the researchers never did anything with the idea?
I would interview a couple of muffler shop installers to see how many cats they've remove that are candidates for cleaning/rejuvenation treatment. You know, look physically good (the ceramic isn't broken, case not rusted through) but aren't working as advertised.
Another thing to consider with such a cleaning system in a commercial application is the waste stream... concentrated heavy metals, oil, etc in high Ph water solution might be difficult/expensive to dispose of in California. There has to be a way to post-treat on site, but it might be expensive.
09-29-2012, 12:41 PM
#13 (permalink)
T-100 Road Warrior
Not sure why it wasn't put into play...or anyone else picked up the ball. Doesn't matter to me...I'm having fun!
Baking soda will easily neutralize the weak acids in the residue solution.
There isn't an incentive from the shops' point of view as they will lose money fer cleaning yer converter vs replacing it. They do make some money on the parts (parts markup %) as well as the labor fer removing the old and installing the new. They also make some money fer recycling the old part. No shop would throw money out the window fer a cleaning process compared to what they earn fer remove/replace. If they did, they be a fool.
This process is more fer the DIY'er who might have an option to save money compared to a costly replacement. With the exception of the cost of the wiring (switches, box, cord and plug) and the chemicals, everything else I've put into this CatWasher were scrap materials.
09-29-2012, 02:22 PM
#14 (permalink)
T-100 Road Warrior
09-29-2012, 06:22 PM
#15 (permalink)
T-100 Road Warrior
09-30-2012, 03:00 AM
#16 (permalink)
I always used a 5/8'' concrete drill bit mounted in a hammer drill....
09-30-2012, 07:02 PM
#17 (permalink)
T-100 Road Warrior
So as I understand it so far...no one here would clean their converter. Smash it out fer better HP and MPG...don't bother with the emissions. Aftermarket cats only cost $100.
Guess that I've gotten my converter cleaned I can scrap my washer now. Thanks fer the inputs.
09-30-2012, 10:23 PM
#18 (permalink)
I would clean my car's catalytic converter but given the complexity in removing it, I much rather not touch it since it seems to be working as it should. That alone tells me the catalytic converter is running at near 100 % efficiency, even after 11 years.
I do appreciate the effort you put into this though. Any action that can prolong the life of a vehicle and its parts is commendable.
The Following User Says Thank You to CigaR007 For This Useful Post:
10-02-2012, 04:20 PM
#19 (permalink)
DieselMiser
I would worry what chlorine in the water would do tho the catalyst.
10-02-2012, 09:32 PM
#20 (permalink)
Intermediate EcoDriver
Originally Posted by Milwaukee
I am not sure but doesn't water kill cat convertor?
Every gallon of gasoline burned in an engine sends MORE than a gallon of water through the catalytic converter(s). It shouldn't be a problem.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
