Old 09-29-2012, 11:29 AM   #11 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
A new OEM converter fer my T-100 lists around $1600 from the dealership. Online discounts drop it to about $800 not including shipping.
This is the technical paper I am basing my converter washing on...
http://www2.ucy.ac.cy/~chpgsc/arthra...%29%202030.pdf
On the other hand, there are a lot of cars with cats in California, big market, money to be made if your idea works.
Exactly...
After 30 minutes...
Residue at the bottom of the CatWasher...
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 09-29-2012, 12:28 PM   #12 (permalink)
That paper has been reviewed, then published, looks like a decently thorough investigation of one failure mode of one Mazda catalytic converter.
Do you have any idea why the researchers never did anything with the idea?
I would interview a couple of muffler shop installers to see how many cats they've remove that are candidates for cleaning/rejuvenation treatment. You know, look physically good (the ceramic isn't broken, case not rusted through) but aren't working as advertised.
Another thing to consider with such a cleaning system in a commercial application is the waste stream... concentrated heavy metals, oil, etc in high Ph water solution might be difficult/expensive to dispose of in California. There has to be a way to post-treat on site, but it might be expensive.
Old 09-29-2012, 12:41 PM   #13 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Not sure why it wasn't put into play...or anyone else picked up the ball. Doesn't matter to me...I'm having fun!
Baking soda will easily neutralize the weak acids in the residue solution.
There isn't an incentive from the shops' point of view as they will lose money fer cleaning yer converter vs replacing it. They do make some money on the parts (parts markup %) as well as the labor fer removing the old and installing the new. They also make some money fer recycling the old part. No shop would throw money out the window fer a cleaning process compared to what they earn fer remove/replace. If they did, they be a fool.
This process is more fer the DIY'er who might have an option to save money compared to a costly replacement. With the exception of the cost of the wiring (switches, box, cord and plug) and the chemicals, everything else I've put into this CatWasher were scrap materials.
Old 09-29-2012, 02:22 PM   #14 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
After 2 hours of cleaning and backflushed with tap water...
Old 09-29-2012, 06:22 PM   #15 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Just got done with the 2nd wash and backflush. I ended up heating the solution on my induction burner fer the entire solution...talk about hot!
Here's the final result after two 2-hour washes with a citric and oxalic acid solution. A simple rinse from front and from the back. Used my shop vac in blower mode to blow out as much water as I could...
Used 2 new OEM gaskets along with some anti-seize. Shouldn't have to worry about someone taking off with my converter as I also have a full belly pan and side skirts fer them to contend with as well.
If I were to redo this...I think I would try a hot sprayer method instead of the full flow method. At least on the 2nd wash it could be more efficient as I could point the sprayer at the spot(s) I wanted to dissolve away. Of course...with the full flow method I could've washed the converter fer hours on end instead. I just needed a better way of keeping the solution at temp. I did rotate the converter at 90° every 30 minutes so I could git enough coverage.
I did notice after I started up the engine I was gitting water vapor from the exhaust pipe...like when the weather is cold outside in the morning...except it's 82°F and super humid from all the rain. I wonder if that's a testament to the effectiveness of the converter.
Old 09-30-2012, 03:00 AM   #16 (permalink)
I always used a 5/8'' concrete drill bit mounted in a hammer drill....
Old 09-30-2012, 07:02 PM   #17 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
So as I understand it so far...no one here would clean their converter. Smash it out fer better HP and MPG...don't bother with the emissions. Aftermarket cats only cost $100.
Guess that I've gotten my converter cleaned I can scrap my washer now. Thanks fer the inputs.
Old 09-30-2012, 10:23 PM   #18 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
I would clean my car's catalytic converter but given the complexity in removing it, I much rather not touch it since it seems to be working as it should. That alone tells me the catalytic converter is running at near 100 % efficiency, even after 11 years.
I do appreciate the effort you put into this though. Any action that can prolong the life of a vehicle and its parts is commendable.
The Following User Says Thank You to CigaR007 For This Useful Post:
BamZipPow (10-03-2012)
Old 10-02-2012, 04:20 PM   #19 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
I would worry what chlorine in the water would do tho the catalyst.
Old 10-02-2012, 09:32 PM   #20 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Originally Posted by Milwaukee View Post
I am not sure but doesn't water kill cat convertor?
Every gallon of gasoline burned in an engine sends MORE than a gallon of water through the catalytic converter(s). It shouldn't be a problem.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
