Old 10-26-2015, 08:09 PM   #1 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Ceramc coating and thin film lubricant
I can't see where this has been covered before. Anyhow, I just sent in my heads, pistons, valves and bearings to be coated. I'm getting two kinds of ceramic coatings. One is a thermal barrier coat, applied to the piston top and the combustion chamber and valve faces. This helps keep heat inside of the engine. If the heat is absorbed into the metal at this point the energy is lost.
The second kind of coating is a thin film lubricant on the bearings and piston skirts as well as the valve stems. I could have done some more items, but I thought this was enough for now. The idea is that I'll not only have more lubrication for engine protection and longevity, but I'll have tighter tolerances, allowing me to use a thinner oil grade. I'll post back on my progress.
The Following 4 Users Say Thank You to Isaac Zackary For This Useful Post:
101Volts (09-28-2016), freebeard (10-31-2015), Joggernot (10-27-2015), MobilOne (10-27-2015)
Old 10-27-2015, 09:24 AM   #2 (permalink)
Sounds good. When my I saw my Metro's engine was low on compression I started looking into these things. They're not too bad and you can even DIY with the right tools.
Old 10-27-2015, 11:05 AM   #3 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Post some links please. I'm interested in doing this in the future.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 10-27-2015, 10:12 PM   #4 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I'm as skeptical of snake oil cans as the next guy, and I'm sure it's not as effective as an engine tear down and proper coating, but as a mid life freshen up, Liqui-Moly sell this:
LIQUI MOLY - Motor Oils, Additives, Car Care - Cera Tec - ceramic-based premium oil additive for extreme high loads
It's OEM approved and independently tested, and I've been curious to try it out for a while. I'm thinking of trying it on the Prius and Jeep (UFI already has coated cylinder bores).
An interesting test:
Old 10-27-2015, 10:27 PM   #5 (permalink)
silverado30mpg - '90 Chevrolet Silverado 2WD w/ 3.08 gear
90 day: 18.91 mpg (US)
BuzzBuzz - '91 Suzuki Swift GT
90 day: 159.12 mpg (US)
I'd just run ws2. Checkout lowerfriction and if you google you can find 'how to' instructions on applying it. If you google yeti and ws2 you'll see someone else who really loves it too. I run it in everything except my automatic transmissions. Works awesomely on bicycles too (roller chains and bearings).
Old 10-28-2015, 02:57 AM   #6 (permalink)
Full sized hybrid.
Molybdenum disulfide (MoS2) does work wonders at lowering friction. Great stuff for things like CV joints. But it also breaks down at engine temperatures and ends up eating away the iron making iron sulfide. I'd imagine that WS2 would do the same.
The coatings I'm getting are Teflon based, or at least that's what I understand. Check out Swain Tech, for an example.
The Following User Says Thank You to Isaac Zackary For This Useful Post:
Xist (10-31-2015)
Old 10-30-2015, 03:26 AM   #7 (permalink)
Have you ever recorded your warmup time (idling the engine)? If the piston/head coating works, you should be able to notice an increase in warmup time.
Old 10-30-2015, 07:45 AM   #8 (permalink)
Send a message via MSN to markweatherill
I'm sure it's a step up from Slick 50
Old 10-30-2015, 04:07 PM   #9 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Yeah, that or a Prolong demo.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 10-30-2015, 05:11 PM   #10 (permalink)
Full sized hybrid.
Smile
Sadly no. This car doesn't have any sort of temperature gauge. Well, now that I'm rebuilding the engine I'll install an oil temperature and a cylinder head temperature gauges. So I won't be able to compare. All I'll have to go by is that the normal operating temperature should be between 300° F and 350° F CHT. So if it's lower that would be a sign the thermal barrier ceramic coating is working.
As far as the thin film lubricating coating goes, I'm skeptical that it really helps too. But I though, why not.
