Old 01-08-2014, 10:17 PM   #81 (permalink)
Reverse-Trike EV
Giovanni LiCalsi's Avatar
image-1871.jpg Photo by sunworksco | Photobucket
This is—as they say—relevant to my interests. I visited www.inrekor.com but didn't find this drawing. Where is it from?
The projects they show go way beyond the refinement of that design.
Can non-flat parts be cut and folded like this, or must they be maufactured in 3D?
The aluminum must be cut, then formed. Then the polypropylene foam board must be heated in a steam cabinet until it is malleable for forming into the shape of the aluminum part. The parts can be laminated after they cool and dry.
Kind Regards,
Giovanni
http://www.steamcar.net/stanley/fastest.pdf
The Following User Says Thank You to Giovanni LiCalsi For This Useful Post:
aerohead (01-09-2014)
Old 01-08-2014, 10:43 PM   #82 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
"Crash tests have proven it among the strongest chassis.
All it takes is waterjet cutting the aluminum and polypropylene sheets, then bonding the sheets together. It's not that expensive."
I would have to see $ with shipping, and long term fatigue results. There are many other Composite Sandwich construction methods with a track record, and
"not that expensive" is highly relative. I'm still trying to find a "reasonable price and availability" for pultruded composite rectangular tubing in small quantities.
I don't have a water jet cutter, and I bet they are not cheap.
I did a quick look at their site and did not investigate very far, had to make dinner, but I did not see any completed vehicles with a long history.
Old 01-08-2014, 10:57 PM   #83 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
OK, I found a price, 6900 Pounds Sterling, not including 1400-1600 more for suspension components. Not in my ballpark, yet.
Old 01-09-2014, 01:08 AM   #84 (permalink)
Reverse-Trike EV
The cost is low if you have the aluminum and foam waterjet cut at a shop. It will cost less than $500.00 to cut all of the chassis parts, if you have the parts in a cad drawing.
The 3-M adhesive is not that expensive. Their are multiple ton presses in The San Francisco Bay Area that can press the laminations together. It only needs to be in a press for an hour.
The chassis panels go together like Lego pieces and the fastener lugs are incorporated along the edges of the panels in strategic places. Inrekor panels were designed for simplicity and affordability.
Kind Regards,
Giovanni
Old 01-09-2014, 07:02 AM   #85 (permalink)
I read the story about the flying canoe. So here's a picture—in the rafters of Hutch's bicycle shop is a dugout cedar Soapbox derby racer from IIRC 1941.
I like the rear suspension. it's similar to the Austin 1800
Are you working with this material?
Old 01-09-2014, 11:25 AM   #86 (permalink)
Reverse-Trike EV
I'm planning to use Alulight aluminum foam panels.
Nice soap box racer.
Kind Regards,
Giovanni
Old 01-09-2014, 02:19 PM   #87 (permalink)
It was CNC'd (cut 'n chopped) out of a cedar billet.
Old 01-09-2014, 03:42 PM   #88 (permalink)
Reverse-Trike EV
Check this video out.
Sculpting a Woman's Body - 3D CNC Foam Carving with FROG3D - YouTube
Kind Regards,
Giovanni
Old 01-09-2014, 06:02 PM   #89 (permalink)
Cnc
Originally Posted by Giovanni LiCalsi View Post
I believe that Scaled Composites is doing aircraft fuselage this way with a 5-axis router,with foam billet as long as 35-feet.
Old 01-09-2014, 06:08 PM   #90 (permalink)
Reverse-Trike EV
Great time saver!
I have a friend that used to be employed at Scaled Composites.
Kind Regards,
Giovanni
