Old 11-03-2013, 06:10 PM   #1 (permalink)
90 day: 29.44 mpg (US)
Check transmission light
More details to follow.
Old 11-03-2013, 06:14 PM   #2 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
it would be hard to give fewer details....
Old 11-04-2013, 03:28 PM   #3 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Its the wheel speed sensor.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 11-05-2013, 11:47 AM   #4 (permalink)
I had my girlfriend come over and I used the Ultragauge. It showed P300, P301, and P302 as pending, but I thought those were leftover from Bacon. It showed P1399 and that seems to go with the 300s, but I cannot find anything relevant to the check transmission light. Whenever I do a keyword search on any result that comes up, it does not find "transmission!"
So, going to try to study for my test...
Old 11-05-2013, 12:42 PM   #5 (permalink)
Phantom's Avatar
What type of car is it and what year?
Old 11-06-2013, 06:57 PM   #6 (permalink)
This is Chorizo, my Civic. The light was blinking when I left drill Sunday afternoon and, not knowing where would be open, I decided to carefully drive home and stop at an auto parts store for some bad advice. When the light stayed on, even after rebooting the car, I pulled over, not realizing that the transmission fluid did not have a dipstick, but not knowing what else to check. It was only later that I realized that I should have checked my parking spot for leaks.
I was really trying to get back to studying, three days of drill and then two tests for which I simply did not have time to study. I hope that I did okay on them.
My girlfriend was over, so I pulled my Ultragauge from Bacon to see if I could get any useful information. It showed misfire codes, which I thought were from my Forester. I was just going to not drive until after my tests, and then straight to the nearest shop, but someone suggested resetting the codes, which I did, and then realized that the check transmission light was off, so I drove 25-30 miles and Chorizo drove fine, no lights, error codes, weird noises, or anything.
So glad that I was worried and distracted over nothing.
Strangely, my Civic HX showed the same highway mileage as my Forester.
That just is not right.
Old 11-07-2013, 08:43 PM   #7 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
Did you change the engine size on the Ultragauge and reset any adjustments you'd made to the mileage or odometer?
Camry Thread
E-Bike Thread
Old 11-08-2013, 10:39 AM   #8 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Check transmission light in a manual car? I'm guessing the light is for the CVT HX.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 12-01-2013, 02:25 PM   #9 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Most likely ignition coil/distributer problem causing all 4 cylinders to miss intermittently. Check the plugs and see if what brand thy are and if they are worn.
Burn lean and prosper \\ //
Old 12-01-2013, 02:28 PM   #10 (permalink)
Was it rainy/damp when the light was flashing? The engine light flashes for a severe misfire.
