Old 09-17-2024, 01:42 AM   #31 (permalink)
Originally Posted by Logic View Post
So it has a normally open throttle valve just to charge vacuum powered ancillaries during overrun and braking/ (free power)
AFAIK the brake booster is the only vacuum-powered device on most (if not all) modern cars.
I can see it getting hydraulic pressure to actuate, from the same pump that actuates the VVT, but, at a guess I'd say there's a torque sensor or 2 in the drive-train somewhere that picks up torque coming from the wheels and/or flywheel during overrun..?
Probably a braking sensor, involved in decisions to..?
I don't know how the electro-hydraulic actuators of the intake valves work, but the throttle plate is entirely electronically-controlled and actuated.
And most newer cars have electronic throttle pedals, regardless if gassers or Diesels.
Old 10-14-2024, 01:01 PM   #32 (permalink)
A few years ago BMW did a study that indicated 3/4 throttle acceleration was optimal. Also note that slow acceleration will affect traffic flow and the traffic signal operation algorithm.
Old 10-15-2024, 01:14 PM   #33 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Sounds close to the 80% load I heard about a while ago.
Old Yesterday, 01:39 AM   #34 (permalink)
Having learned to drive in a car without a tach, maybe relying on some random arbitrary pedal-based measure could be simpler, yet sometimes it doesn't work in real-life driving. I remember so many times hitting the pedal to the floor while the Opel Corsa B struggled to keep RPM before I had to shift to a lower gear...
