Old 08-19-2011, 01:50 PM   #11 (permalink)
gtstanger01's Avatar
The Turd - '01 Hyundai Elantra GLS
90 day: 33.16 mpg (US)
The Brick - '06 Dodge Durango SXT
90 day: 15.35 mpg (US)
The Money Maker - '07 Volvo VNL 780
90 day: 6.22 mpg (US)
The New Money Maker - '07 Volvo VNL780
90 day: 6.84 mpg (US)
Vdub - '12 Volkswagen Passat SE tdi
90 day: 37.78 mpg (US)
I don't own the trailer so that's out. Pittsburgh power makes a muffler for my truck and a system that is suppose to remove the air from the diesel fuel. A performance muffler I know would make a difference. Its not that expensive either only $158. They claim .3 mpg gain. The other part, the air removing system, I am a little skeptical about. After talking with my step-dad who works in the fluid and filter division at Cat, and also has a master degree in chemistry doesn't see that system working as is, although it can be done. Any comments?
As far as slowing down, i usually only run 62-65 mph. I work for an expedited freight company so time is usually an issue. If I slow down to much I would have trouble meeting time deadlines.
If I can stay around 62-63 mph I can get around 6.2-6.5 mpg
Old 08-19-2011, 02:04 PM   #12 (permalink)
http://www.snowperformance.net/produ...on_pdf-134.pdf
The cummins diesel VP endorses it and dieselpower magizine has tested it on and off since 2006.
Old 08-19-2011, 07:11 PM   #13 (permalink)
90 day: 19.36 mpg (US)
Nice to see that you have some restrictions in the sense that all is not wide-open, thus any ideas about FE have a narrowed field to work in.
The muffler seems like a no-brainer.
IMO, same for a MANN-HUMMEL centrifuge and trending oil analysis to keep changes to a minimum. MOBIL Delvac 5W-40. See posts by Doug Hilary on www.bobistheoilguy.com; a fleet owner and international trucking consultant going back to the 1960's. He specs a full-flow stainless filter at the standard position. Changes are pushed out a good ways.
Same for tire design: going for rib tires at as many positions as possible. I'd also want a TPMS (tire pressure monitor system) as I hate having to air up tires the last driver "forgot" . . at least it would only be the trailer. Super singles worth looking at. Search for the Rutherford/Mallinson glider kit being sold by a firm in TN, some possible good ideas there.
Same for alignment. I'd want the tractor "perfect" in all small details. Shocks, bushings and especially correct any steering wander.
As to the FASS fuel system it would be worthwhile to duplicate (if not already present) the quality of the dual filter setup. It isn't that expensive. Or, a DAVCO setup (which I like as it makes things simple; Wal-Mart also uses these so you know they've crunched numbers. Shoot, anything they do is probably worthwhile).
What about the ThermoKing APU? Not cheap, but the expedited guys I know are "on" 24/7, waiting around in their trucks. An idea about fuel use over X-time (life of tractor as you see it) would make the numbers clear to payoff on the APU (unless you're in CA a lot). I would figure high-idle fuel consumption at either .75 or .80 gph on the main engine.
Would be worthwhile to look over dash gauges. IAT, EGT and MAP all work together. Air filter restrictions, too (DONALDSON Powercore would be my air filter choice; ask Mallinson); but not changing until necessary would be best (dash gauge).
The lag time of engine oil warming is another topic covered by Hilary: 15-30" behind coolant. I noticed 40-miles or 35" on a heavy 57' I was pulling recently in 90F TX temps. That's a lot of fuel over a years time. Coolant pre-heat would shorten engine oil temp lag time once underway. Hilary likes to see a close relationship between coolant and oil sump temps. There is an SAE paper on that discussed on BITOG.
Plus, tire temps dont' settle out until after 1.5' of steady-state driving.
Plus the usual about progressive shifting. I would think it worthwhile to shoot an email to VOLVO N.A. about their recommendations on this. Might be something they could speak to. I've had a CDL a good while, but I don't even try to compare my ability at shifting to some of the O/O's I've known, some of them ol' guys are plain spooky they're so good.
KENWORTH and CUMMINS both have White Papers on FE that are good reads.
I always like trip planning for two-hour breaks, and a meal at the fourth hour (whether I eat much or not). Pre-planned stops. Breaks the trip into legs with known times & distances. This relieves the small stresses of where to stop, and leaves more room for fine control over the rig.
I like Google street view for determing what side of the road the stop is on, what parking is like, and how easy to re-enter highway from that stop. Steady pace. Just like I already knew the route.
A high quality drivers seat, too. A bad one (fleet seat) just beats a guy up, IMO. This matters well before hour six behind the wheel. FE is about small changes, but the biggest difference among professional drivers is skill, and skill is about paying attention, first, to small things. A tired driver just won't care as we all know. From best to worst is a 30% spread among those drivers: same truck, same work, one-third different fuel consumption.
Old 09-16-2011, 08:35 PM   #14 (permalink)
Was reading some more last night on Class 8 FE. Came across these:
DEFLECKTOR WHEEL COVERS
The Fleet Air Filter
Microblue Racing Products
And, a retailer of such devices
Truckrfuelmileage
The Microblue site has some interesting stuff on micro-polishing bearings, axle and trans gears, etc. A fairly high claim on friction-reduction. An interesting thread on The Truckers Report entitled: Is 10 MPG Possible with a Fully Loaded (80K gross) 5 Axle Truck? where the above are discussed in light of one O/O's experience.
Since big trucks tend to run 10,000-miles/month, the results can be quick as to calculated effects.
More:
Cummins: White Paper [.pdf] Secrets to Better Fuel Economy
Kenworth: White Paper [.pdf] on Fuel Economy
Fitzgerald Glider Kits
MOLAKULE: SAE Tech Brief: Bulk Oil Temperatures in the Sump verses Coolant Temperatures; A summary.
Old 09-17-2011, 06:24 AM   #15 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 214.18 mpg (US)
Send a message via MSN to jakobnev
Maybe some kind of savings-sharing deal would give the owner incentives to aeromod it.
Old 09-17-2011, 10:51 AM   #16 (permalink)
Rolling Resistance
- Tire size/type & balance
- Wheel bearing friction reduction
- Proper wheel bearing adjustment
- Tire pressure monitoring
A lot of small stuff to consider in re rolling resistance. A search on wheel bearing adjustment shows it may be source of side-to-side temp discrepancies. Too tight is a possibility (improper method; sloppy work).
A product to consider in re wheel/tire balance:
True Balance
