Old 11-01-2011, 04:30 PM   #411 (permalink)
Persephone - '00 Toyota Tacoma SR5
90 day: 18.77 mpg (US)
Originally Posted by bondo View Post
Post some of your fuel efficiency figures you realize with your aero shell.
Thanks,
Bondo
Unfortunately I've been a little low on money since I built it so I haven't had the ability to do "testing" but the figures that I do have are:
just shy of 30 MPG between Jackson and Rock Springs Wy doing mostly 65mph.
About 30 MPG between Laramie Wy and south Denver Co going along I-80 and I-25 largely going 75.
I apologize for not having more definitive numbers but financially I'm not in a position to get mo accurate numbers.
The truck is a 2001 Toyota Tacoma with the 4cyl engine, manual transmission, and SR-5 package. The tires look to be slightly larger than stock but distances and speeds were achevied via GPS.
The Following 3 Users Say Thank You to ajohn7211 For This Useful Post:
aerohead (11-02-2011), bondo (11-06-2011), slowmover (11-02-2011)
Old 11-03-2011, 07:29 PM   #412 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by ajohn7211 View Post
and I put them on the Book of Faces. Click the link below to see them.
AeroShell | Facebook
Here ya go John..
The Following 8 Users Say Thank You to Chris D. For This Useful Post:
aerohead (11-05-2011), BamZipPow (11-04-2011), bondo (11-06-2011), KamperBob (11-04-2011), MkVer (05-09-2016), slowmover (11-04-2011), t vago (11-03-2011), TheMarkofPolo (01-04-2012)
Old 11-03-2011, 07:59 PM   #413 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Awesome! Duct tape - is there anything it can't do?
Old 11-03-2011, 08:17 PM   #414 (permalink)
Stick to hardware cloth. Its been pealing up and I'm having to go over it again. I did the hardware cloth to add support as it snows a lot here in Wyoming but because the contact area that the hardware cloth provides is tiny.
Old 11-03-2011, 08:35 PM   #415 (permalink)
MPGuino Supporter
t vago's Avatar
You could do what some have done here with their wheel covers. Install the hardware cloth, then coat it with fiberglass resin. You might could do several layers of hardware cloth, or you could use the stiffened hardware cloth as a support for several layers of fiberglass.
Old 11-03-2011, 10:43 PM   #416 (permalink)
yeah I have been considering fiberglassing but i've got some design changes i think i'm gonna do for version 2.0 and hopefully that will make things hold up better and be more aero. Maybe add a door or some plexi-glass so i can see out the back occasionally.
Old 11-04-2011, 09:33 AM   #417 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by Chris D. View Post
Duct tape - awesome. Red Green would love it too.
Recreation Engineer
Old 11-04-2011, 09:43 AM   #418 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
Maybe the heat-shrink wrap, used for sealing up boats for storage, would be good when the final shape is not determined yet.
Old 11-04-2011, 12:47 PM   #419 (permalink)
I also considered that but I didn't know how strong the heat-shrink wrap is, if it would of held up under the snow by itself, or how well it would of held up to the sharp ends of the hardware cloth.
Again all changes that I'm considering for version 2.0. I'm gonna do more bent pipe and maybe some plywood and plexiglass.
Old 11-06-2011, 01:59 PM   #420 (permalink)
bondo's Avatar
23 mpg rating by EPA to 30 mpg, not to shabby!
ajohn7211, your 2001 Toyota Tacoma with the 4 cylinder engine and manual transmission is rated at 23 mpg for highway at Fuel Economy
If your preliminary road tests are showing a couple of 30 mpg runs, you and the aero shell you made are evidently doing something right!
Bondo
Easy Aero Fix? (Modding a pickup?) DifferentPointofView Aerodynamics 53 04-13-2012 05:46 PM
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? MetroMPG Aerodynamics 5 11-17-2011 02:35 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
How much do y'all pay for trash pickup? roflwaffle Saving@Home 15 08-23-2009 10:46 AM
Daihatsu Mira aerodynamic modifications newtonsfirstlaw Aerodynamics 5 06-13-2009 09:43 PM
