Old 06-09-2008, 05:18 PM   #1 (permalink)
Warhawk626's Avatar
SlowZoom - '98 Mazda 626 DX
Last 3: 31.36 mpg (US)
Das Tank - '00 Dodge Carvan Base
Considering oil grade switch.. need help
I have been running 10w30 in my car for the past 3 years. I have heard switching to a lighter weight such as the 5w20 may boost FE. My main concern is if my engine can handle it or not. It's a 2.0 mazda 4 cyl with close to 136k miles, always used conventional oil. I considered switching to synthetic as well but I have heard horror stories about loosening sludge and killing the engine. What do you guys think? Thanks in advance.
Roger
1998 Mazda 626 DX
2.0 4 cylinder
5 speed manual
AC and PS Delete
17x7 Drag DR 19 wheels ( I know )
Hankook z rated tires ( again, I know
Future plans: Mazda miata 14'' BBS wheels
Old 06-09-2008, 06:11 PM   #2 (permalink)
Warhawk626's Avatar
I know that the "Zetec 2.0" in the focus is the same as the Mazda 2.0 and I believe they haven't changed that engine since the early 90's.
1998 Mazda 626 DX
2.0 4 cylinder
5 speed manual
AC and PS Delete
Old 06-09-2008, 06:18 PM   #3 (permalink)
I'd go to a 0W30, youve got a few miles there and a 20 might be too thin for an engine with some slop in it.
Old 06-09-2008, 06:26 PM   #4 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Since you live in Louisiana and don't need to worry about winter I would just keep the 10w30. You're not going to see that big improvement in FE with the lighter oil.
"Judge a person by their questions rather than their answers."
Old 06-09-2008, 07:02 PM   #5 (permalink)
Warhawk626's Avatar
Duffman, I think I'm gonna go with your suggestion. I just looked into Amsoil, they have a lot of data supporting their oil. The 0W30 apparently is used in Police Fleet vehicles and is warrantied for 1 yr or 35k miles
1998 Mazda 626 DX
2.0 4 cylinder
5 speed manual
AC and PS Delete
Old 06-09-2008, 07:52 PM   #6 (permalink)
ttoyoda's Avatar
Warhawk626
The "correct" oil depends on the clearance between the bearing shells and the crankshaft, connecting rods, camshaft. A less viscous oil may escape out from between the bearing shell and crank-etc. faster than the oil pump can replenish it.
I would suggest you get a real, mechanical, oil pressure gauge to at least compare what sort of pressures you are getting now, and after the lighter oil. The later versions of your engine may have smaller clearances in the bearings than yours does.
Old 06-09-2008, 10:22 PM   #7 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Lightbulb
Guys, it's mostly Ford and Honda that spec 0/5W-20 oils ... and I don't think they redesigned a single engine with this thinner oil in mind. All the engines that call for it are older designs with the same clearances as when they called for 5W-30 (like Dad's Mercury Grand Marquis with its 4.6L V8).
I've seen dozens of UOAs (Lab tests) using 5W-20 and they usually look superb. I'd use 0/5W-20 without much reservation. Just don't go over 5,000 miles without doing a UOA from a place like this:
http://www.blackstone-labs.com/gas_engines.html
--- Bror Jace
Old 06-10-2008, 12:12 AM   #8 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
If you have been changing your oil like you should I'd go right to synthetic and not look back. Be honest, have you been a good boy? If not I'd use the high mileage blend that valvoline makes in a 5-30. If no leaks after a few thousand miles you could get away with a synthetic or a 5w-20 motorcraft blend. Like the above poster said you should get a reliable oil pressure gauge and at least go to the 5-30 of the same oil you have been using and see what the gauge tells you. To make this even more complicated, some 10w-30s end up being "thinner" after use than a 5w-30.
Old 06-10-2008, 12:15 AM   #9 (permalink)
Blue - '77 Chevy P/U
i run 5w30 in a 350
Old 06-10-2008, 08:15 AM   #10 (permalink)
Cheapsake mo-bile - '91 Ford Festiva
90 day: 39.51 mpg (US)
I'd try it. I'm running Motorcraft 5w20 in our Aspire that has a Mazda designed 1.3L. It loves that particular oil. If you taken care of it I wouldn't worry about killing it the Aspire has 208k on it. With all the changes I can't say for certain but I think it gave me about a 2 mpg increase.
04 Escape 3.0L - 91 Festiva /Auto
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Alberta Oil Sands Gone4 The Lounge 8 02-19-2008 07:58 PM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
