Old 06-27-2010, 01:11 AM   #21 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
Originally Posted by Old Tele man View Post
...they'll "roll" further before stopping because they have lower hystersis (power eating) than other tires.
I kind of figured that much. I'm just not clear about how they achieve the lower rolling resistance. Is it by compound and/or tread design, or is it simply by way of being made to run at a higher pressure?
Do you know if anyone here has tried them out and collected data on FE and rolling resistance changes?
Old 06-27-2010, 06:28 AM   #22 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by white2001s10 View Post
.........I'm just not clear about how they achieve the lower rolling resistance...........
Basically RR is caused by the amount of deflection, the amount of rubber being deflected, and the internal friction of the rubber (hysteresis).
So when a tire manufacturer wants to reduce the RR, he will take rubber out of the tire and / or change the rubber to one with a lower hysteresis. Both of these things negatively affect treadwear and traction (especially wet traction)
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
My Continental Contact-Pro Tires cfg83 EcoModding Central 16 05-08-2010 01:33 PM
Bridgestone Tires and LRR gone-ot EcoModding Central 30 05-04-2010 12:31 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
