Old 01-25-2011, 03:46 PM   #11 (permalink)
...beats walking...
...might be an excellent idea down here during the Monsoon Months when temp's are 95-115ºF and humidity is like a "wet sock" slap-in-the-face (pun intended).
Old 01-26-2011, 05:51 AM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Do I see a silica gel group buy coming?
Old 01-26-2011, 06:57 AM   #13 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Originally Posted by brucey View Post
I hate having to run the defroster in winter, knowing it's turning on the A/C.
With my LED Fan On indicator, I have noticed that the AC does not run with defrost when it is bitterly cold; like below 20F.
I like the silica defrost sock idea!
-Terry
Old 01-26-2011, 08:02 PM   #14 (permalink)
Slowpoke - '00 Hyundai Sonata GLS
90 day: 32.82 mpg (US)
Sweet idea! I can imagine using silica gel to prevent the fogging problem in a secondary windshield aeromod.
Slowly modding my 2000 sonata to what it should be... one project at a time.
Old 01-26-2011, 09:38 PM   #15 (permalink)
Niner_xA - '05 Scion xA
90 day: 35.82 mpg (US)
Horse Hauler - '95 Ford F-250 XLT
90 day: 13.47 mpg (US)
Butterkup - '02 Mazda Miata
Check out the kitty litter area at your local grocery or petstore. I've seen a "litter" that's just silica gel crystals. I've used that before for making motorcycle coolant vests (soak in water so the gel picks up moisture but doesn't "drip", which provides evaporative cooling - sort of a like a swamp cooler).
The Following User Says Thank You to Niner For This Useful Post:
redpoint5 (10-19-2018)
Old 01-26-2011, 10:34 PM   #16 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Every pill bottle has silica gel in a little paper packet to keep the pills dry, you can also get silica gel for drying flowers or as was stated, as crystal cat litter.
I was just using some that changes color, blue is dry, pink is wet, it works really well for drying stuff out like cell phones or if you are me, my lap top that I dropped in to standing water... a few hours in a bag of silica gel and it's dry and working just fine!
Personally, I just leave my window cracked open over night, the moist air wants to condense on what is coldest, if the window is open then the coldest thing is the outside as the windshield is still warm, but the windshield is quick to cool so it frosts up quickly.
You can also dry silica gel in the microwave, I don't have one so I used the one next door and found that putting it in for a minute, take it out and stir and cool then put it in for another minute, a flat glass bowl worked best.
Old 01-27-2011, 03:23 AM   #17 (permalink)
Laura the Lancer - '81 Mitsibishi lancer LX
what a brilliant idea!!!
as my car doesnt have a/c or a fan!!! i use "fog clear" pretty much isopropyl alcahol or something, it works alright but this is going to have to be product tested
Old 01-27-2011, 06:16 AM   #18 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
crystal cat litter
Do you know any good brands?
Old 01-27-2011, 01:14 PM   #19 (permalink)
The cat litter crystals I got was just store-brand - just make sure you get the stuff that's *only* crystals (which are a translucent white) and not crystals in clay, because the clay will break down as it goes through wet/dry cycles.
Old 01-28-2011, 11:42 AM   #20 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
You can also pay for silica gel from gun shops or places online like MidwayUSA. It is used in safes to prevent rust. I pull it from shoe boxes & vitamin/pill bottles also. This way takes a long time to get much gel, unless your wife likes shoes as much as mine does.
Remington makes a "mini-dehumidifier" that plugs into an outlet to get the water out of the silica gel.
There are also some clay products that absorb water out of the air. I believe they are also rechargable. I will have to check on a brand when I get home.
Don
