Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 11-22-2011, 07:32 PM   #11 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
I retract the comment about radioactive elements in sparkplug electrodes.
ENGINE VOLTAGE REQUIREMENTS USING SPARK PLUGS PRE-IONIZED WITH RADIOACTIVE GOLD
Edit: at least with Beta radiation. With Alpha radiation there may still be a possible improvement.
Edit Edit: it would help with cold starting though
Old 11-22-2011, 08:28 PM   #12 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Piwoslaw View Post
From what I've read on these forums (and if I haven't mixed it up), the actual combustion process itself is very close to something like 95% or 99% efficient.
I often question these numbers as they seem to refer to the after cat burn rate, where your fuel gets burnt is more important than how much of it eventually burns. When a typical Detroit motor is running open loop with a 10-12:1 AF ratio 95% of the fuel cannot burn completely in the motor because there isn't enough air.
I am always reminded of the funny cars with the flames coming out of the tailpipe.
Steady state at full operating temperature I don't doubt 95%+ is possible, but during acceleration, warm up or most any other time including idling I doubt anywhere near 95%. Take the cat off a warmed up modern car and take a whiff of the exhaust, if it smells like gas it isn't burning 99%.
Old 11-22-2011, 09:16 PM   #13 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
i dotn have cats in my 07 charger. and it does smell like gas untill i leaned out the tune more and now its not as bad.
Old 11-22-2011, 09:29 PM   #14 (permalink)
rmay635703's Avatar
I would love to lean out my 010 cobalts tune, no idea how without a boatload of cash though.
Old 11-22-2011, 09:42 PM   #15 (permalink)
well after I did the headers and other mods. i was at the track and got kicked off for the night because i dumped raw fuel out the tail pipe to the 60' mark. so off to the dyno and tuner i go. a few hours later we got the tune right. I can say the chevy tunes are easier to do and chevy tuners are easy to come by.
Old 11-25-2011, 07:48 PM   #16 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
Originally Posted by ConnClark View Post
Small piston aircraft have dual sparkplug systems. Part of the warm up and check procedure is to run off one side then the other to check for fouled or faulty plugs or a bad magneto. Normally you run off both and you can usually feel/hear that they get more power from the same amount of fuel running on both sparkplug systems.
I believe that most of the difference goes away if the timing is advanced when running on single plugs. Longer flame travel distance on single ignition needs more spark advance.
Old 11-25-2011, 09:29 PM   #17 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
The other, often overlooked fact of multi-ground strap plugs is that they take up more space in the combustion chamber, and bump compression slightly.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 02-28-2012, 10:37 PM   #18 (permalink)
Subievangelist
evil03mustang's Avatar
Send a message via AIM to evil03mustang
I had a Chevy Prizm with the 1.8L DOHC 1ZZFE engine, and it actually REQUIRED these twin-electrode Denso plugs. :shrug: Go figure.
I miss that car. Blew a connecting rod through the oil pan.
Got 34MPG no matter how I drove it.
Old 02-28-2012, 11:22 PM   #19 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
evil03mustang -
Wow, I think I would like that requirement. I'd iesearch it until I found the Yoda who knew why. Here's an old news release from 2010 :
DENSO to Release Fuel-saving Spark Plug / News Releases | DENSO CORPORATION
CarloSW2
American Solar Energy Society
Old 02-29-2012, 01:14 PM   #20 (permalink)
...beats walking...
...plus, all those metal straps begin to act like both a "heat-sink" and mechanical "shield" around the central element...two physical events that actually reduce the chances of proper, reliable, operation!
