Old 12-03-2009, 10:32 PM   #31 (permalink)
Civical - '02 Honda Civic EX
90 day: 33.74 mpg (US)
The transmission in the Civic has been a bit of adjustment for me. The "Grade-Logic Control" confused me for a while, since my car was engine braking by itself. So, I use neutral on some hills.
Old 12-06-2009, 12:09 AM   #32 (permalink)
DON'T DO IT!
About 30 years ago I burned out the clutches in my A/T by coasting this way. The problem doesn't come from throwing it out of gear, it's that you can't shift back into gear without incurring damage (unless you coast to a full stop, then put it back into drive.)
It was a very expensive lesson that I never forgot.
Old 12-07-2009, 01:49 AM   #33 (permalink)
Originally Posted by Thmeclock View Post
DON'T DO IT!
I don't mean to be disrespectful, but that was an older transmission. Many of the newer transmissions are electronically controlled, and don't just throw themselves into the lowest gear when moved from "N" to "D."
Old 12-07-2009, 03:46 AM   #34 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
My 20yo automatic will even rev match automatically. If I try to bump up the revs myself I get a sloppier engagement from N to D.
Old 12-07-2009, 09:53 AM   #35 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by Ryland View Post
check your owners manual, I would say the section on towing the car in neutral, because it's going to tell you how fast you should have it going out of gear, as some tell you not to tow over 30mph with the drive wheels on the ground.
everyone always aludes to 'towing anf your owners manual' which has NOTHING to do with coasting w/ engine on. Unless your are being towed with your engine on!!!!!!
I have owned 2 cars in the last 9 years : 1997 toyota Avalon & 2002 Infiniti Q45.
I costed extensively in both of these car. sold the Avalon at 215,000miles and the Infiniti currently has 185,000miles. I never had a transmission problem with either car.
Old 12-07-2009, 12:37 PM   #36 (permalink)
Unless your transmission was specifically designed with the option to be shifted, (as some are) we don't know for certain what the consequences might be. I wouldn't want to find out the hard way, as I once did.
OTOH, it can be done effectively with a manual tranny - so that's the best option for utilizing coasting.
Old 12-07-2009, 10:09 PM   #37 (permalink)
I wouldn't want to find out the hard way, I can't say I blame you for that. However, with a transmission like mine, it's really not a big deal.
Interesting. What car is that?
Old 12-07-2009, 10:52 PM   #38 (permalink)
roflwaffle's Avatar
It's the first one under my user pic.
Old 12-17-2009, 02:41 AM   #39 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
I should just shift my transfer case into Neutral. HA!
The one thing I would like to get for the truck is free-wheeling hubs.
Dodge has a 'great' idea that I can engage / disengage 4wd from the cab with the pull of a lever. However, the front axle shafts are ALWAYS spinning. UGH!
Old 05-06-2010, 11:04 PM   #40 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I can't figure out what ya'll are talking about. I've towed cars miles and miles just by putting them into neutral, no problems. I neutral coast constantly in all my vehicles, sometimes even switching off the engine. So long as I start the engine before reengaging drive, I've never had a problem.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 12:08 PM
Automatics and Neutral? Gone4 Hypermiling / EcoDriver's Ed 19 10-09-2013 03:32 AM
Regearing a tranny - Toyota Tercel Daox EcoModding Central 27 05-29-2010 10:32 PM
Turning the car off at stop lights (questions about when, how long & wear issues) NoCO2 Hypermiling / EcoDriver's Ed 27 05-06-2010 11:30 PM
Cheap Fix for a Tranny line? WaxyChicken Off-Topic Tech 18 02-14-2008 04:29 AM
