Old 02-11-2017, 08:28 PM   #21 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Just read this old thread (I am a relatively new member and trying to catch up on everything)
Would it not be beneficial to insulate the entire exhaust system with exhaust wrap? That would keep the temperatures higher which could mean that the dpf burns up the particulates stuck in it faster.
Just a thought...
The Following User Says Thank You to teoman For This Useful Post:
gumby79 (02-11-2017)
Old 02-11-2017, 10:56 PM   #22 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Fresh ideas
Sounds like my 1500w heatgun is just under the required temperature.
Did an experiment mesured power consumption with a Kill A Watt gauge ,on a 1500 w heat gun/internal digital thermometer/ thermostat
maintain + - 5°f (2°c) 932°f (500°c)
max temp/ Max fan
warmup 1289w 11.08A
Maintain 932°f 1089w to 1289w cycletime ~ .5sec high ~ 1 sec. Low
Max temp/ Min fan
Warmup 1156w 10.98
Maintenance 771w to 1109w cycle time ~ .25 high ~ 1 - 2low
Fan only
57.8 watts .30A
add a few drops/min of diesel and you have a regen temperature without the engine running . Well under the max load for a standerd 110vac wall plug. Wether or not the CFM is within specifications to clear the ash without allowing it to become one with the ceramic. I dout it ... this could be run off a properly sized bank of suppercaps/supplemental Deep Cycle Battery to alow the regen to finish what it started.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Phantom (02-21-2017)
Old 02-12-2017, 04:17 AM   #23 (permalink)
teoman's Avatar
A3 - '12 Audi A3
If for home use,
This sounds like a perfect excuse to build an electric foundry. But with one door that has a heatproof hose compatible for the dpf.
Old 02-12-2017, 06:56 AM   #24 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
The solution to my VW's DPF woes was to use DPF cleaner (bought cheaply in bulk from a tractor supply) and use it every tank.
One time it took 200km of highway miles to get the DPF light to go out. With DPF cleaner, problem solved, never had a light since.
The fuel saving seems to be about the same as the cost of the additive.
Renault are claiming the DPF in my new Trafic is good for life, and they claim the engine is good for 400,000km. I'm still using the additive.
Old 02-12-2017, 12:01 PM   #25 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
good for 400.000, but lasts longer if treated well.
We have a lot of vans driven a half million kms here.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
