Old 06-19-2017, 03:28 AM   #291 (permalink)
Originally Posted by Fingie View Post
i am also a man of principle, ill at least try to fix before i replace it
Considering that sometimes a makeshift repair can be not just more cost-effective, but also last longer than a standard replacement part, sounds reasonable
Old 06-19-2017, 04:24 AM   #292 (permalink)
Renee - '92 Renault 50 Series
90 day: 21.21 mpg (US)
EscortEstate - '97 Ford Escort mk6 ANL
90 day: 37.66 mpg (US)
why the rush?
Perhaps in need of a toilet ?
Shame about your coolant tank, althought I feel that a replacement would be better, if you can fix it - give it a try, if it fails well you can always replace it.
Next week my finish mpguino should arrive, so I'm hoping that I can get that installed over midsummer and then I can try to squeeze out a few more km to a liter.
Speaking of midsommar, I might have to raid the forest and make some bastukvastar, then have a few midsommar saunas. I have an italien friend I'm sure that it will be new experience to hit himself with twigs from a tree
The Following 2 Users Say Thank You to MJamson For This Useful Post:
Fingie (06-19-2017), teoman (07-16-2017)
Old 06-19-2017, 09:50 AM   #293 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
"Nothing is more permanent than a temporary solution"
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
The Following User Says Thank You to Fingie For This Useful Post:
MJamson (06-19-2017)
Old 07-01-2017, 01:51 PM   #294 (permalink)
Fingie's Avatar
Dang it, the War Wagon did not pass inspection.
the brake power was too weak in the right rear wheeö, and the handbrake was too weak on the roll brake tester.
well, i checked by pulling the drum and the brake cylinders were pretty much stuck wiggled em a bit though.
last years inspection they were ok.
I WONDER...
if it's because i've learnt to drive in a more... Engine brakey way, hmm?
Old 07-01-2017, 04:41 PM   #295 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Little use can also be detrimental to equipment. You are lucky the abs pump did not fail.
Old 07-02-2017, 05:12 AM   #296 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
Look at the bright side, i suppose you buy all the stuff you need for the rear brakes for like 100-150 euros? And those will probably last the next ten years
Meaning, replace 'em all while you're at it.
The Following User Says Thank You to iikhod For This Useful Post:
Fingie (07-03-2017)
Old 07-03-2017, 10:01 AM   #297 (permalink)
Fingie's Avatar
What ABS pump
first lada/vaz to get one was Kalina in 2007 or so
well, bought rear brake shoes and springs for 24 buck or so (probably the same in e and USD lol)
Old 07-06-2017, 01:38 PM   #298 (permalink)
Fingie's Avatar
gotten good mileage for now. And aero is still untouched except for a partial grille block
Old 07-06-2017, 03:32 PM   #299 (permalink)
The cheapest, easiest and best mpg gains are with the money at the wheel
Old 07-11-2017, 12:11 PM   #300 (permalink)
Fingie's Avatar
the nut behind the wheel is well-adjusted
