Old 01-06-2013, 01:15 AM   #11 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Best way to test this is to pick up some hubcentric spacers and see what happens.
In Reason we Trust
Old 01-06-2013, 02:05 AM   #12 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
But how to test the opposite direction offset?????
Old 01-06-2013, 11:40 AM   #13 (permalink)
AeroModder's Avatar
Team Ford
Pick up a set of wheels with a high offset, then gradually move it out with spacers. If you change the wheel design, that will affect the airflow and it won't be an apples-to-apples comparison.
In Reason we Trust
Old 01-12-2013, 01:35 PM   #14 (permalink)
rav
Gas HOG - '08 JEEP LIBERTY SPORT
Thanks for the replies just ended up getting one of the most lightweight and aerodynamic wheels that Honda made:
Best of all they are made for a Honda fit with the same offset!!
The Following 2 Users Say Thank You to rav For This Useful Post:
aerohead (01-12-2013), Vwbeamer (06-10-2022)
Old 06-09-2022, 04:06 PM   #15 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I am at the moment doing CFD simulation to the offset matter. I am using a Drivaer 3d model with just drivers side and front wheel. Wheel is fully closed in the simulation so there is no cooling holes at the moment. So far it seems that if you move wheel inwards it helps with the drag. In first simulations wheel is not rotating.
- mm is inward movement
+mm is outward movement
+40mm 0,4961
+30mm 0,4870
+20mm 0,4908
+10mm 0,4896
STD 0,490
-10mm 0,4926
-20mm 0,4900
-30mm 0,4829
-40mm 0,4835
Next I will put convex hubcab there which will come outwards +20mm at the center. And for next runs I will also take down the actual forces as the frontal area changes little bit so the drag coefficient calculations are not exact. Frontal area grows from A=1,0218m2 to A convex capsels=1,0226m2
My guess for sweet spot is between -20 to -30mm range. Specially when wheels are rotating
After that I will try to put it then rotating. Pics will follow later
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (06-09-2022), Piwoslaw (06-10-2022)
Old 06-09-2022, 10:02 PM   #16 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
+40mm 0,4961
+30mm 0,4870
+20mm 0,4908
+10mm 0,4896
STD 0,490
-10mm 0,4926
-20mm 0,4900
-30mm 0,4829
-40mm 0,4835
any thoughts on the hyundai ioniq blues hubcaps?
alloy, drag, offset, steel
