12-05-2008, 04:52 PM
#11 (permalink)
side skirts
The only thing I have "scientific" for side skirts is from the development of the 1982 Pontiac Trans Am.--------- The skirts provided a 4.4% drag reduction.------------ When combined with the under-car wrap-around front airdam,drag was reduced 7%,which would yield a 3.5% improvement in mpg at 55-mph.
04-03-2022, 11:36 AM
#12 (permalink)
Rookie Ecomodder
Dodge did this back in the late 80's too.
The Following User Says Thank You to rollercoaster For This Useful Post:
04-04-2022, 10:28 AM
#13 (permalink)
skirt clearance
Best I can tell, the SAE still recommends :
1) a 16- degree 'approach' angle ahead of the front tires.
2) 10-degree 'breakover' angles behind the front tires, and ahead of the rear tires.
3) 10-degree 'departure' angle behind the rear tires.
4) If these angles are not respected, you run the risk of a ground strike and body damage.
5) 'Active' airdams were introduced in the early 70s by VOLVO on their VCC concept, and would be a 'workaround' for the front clearance.
6) 'Active' diffusers were introduced by GM in 1982 ( Aero 2000/ EPCOT concept ), and would be a 'workaround' for the rear.
7 If you're willing to take all driveway ramps at an oblique angle, you might be able to survive with a 'cheater' set of skirts or wheel fairings.
The 'template' illustrates a wheel fairing package ( or skirts ) which respects all SAE underbody clearance requirements.
PS, rubber belting would be able to survive ground strike and abrasion, although it would be subject to aeroelastic deformation.
PS-2 In the State of California, expect the Highway Patrol to pull you over if they see any part of your car lower than the bottom of the wheel rim.
04-06-2022, 02:33 AM
#14 (permalink)
2020 - '08 Chevy Tahoe H Last 3: 18.4 mpg (US) 2021 - '08 Chevy Tahoe H 90 day: 17.08 mpg (US) 2022 - '08 chevy Tahoe LT Last 3: 14.38 mpg (US) 2023 - '08 Chevy Tahoe Last 3: 22.61 mpg (US) 2024 - '08 Chevy Tahoe 90 day: 22.35 mpg (US)
buy a bigger rim then
The Following User Says Thank You to Tahoe_Hybrid For This Useful Post:
04-07-2022, 01:57 PM
#15 (permalink)
I remember side skirts were quite usual in the '90s as part of aerodynamic kits, even though people simply bought them because of the "go-fast look". Once in a while I still see some Opel Corsa B with side skirts and a rear spoiler.
