Old 12-06-2010, 09:01 PM   #161 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
Once again, effects of CR on power
Engine Compression Ratio - Tech - Popular Hot Rodding Magazine
Now, you dont have to believe it at all. In fact, you dont have to read it. But ignoring facts doesnt make your imagination reality. That is only unfortunate for you. Diesel and gasoline engines benefit greatly in their efficiency from higher CR's.
Old 12-06-2010, 09:04 PM   #162 (permalink)
Agreed autoteach.
http://www.greencarcongress.com/2010...1020.html#more
The new Mazda has a CR of 14to1 close to what Indy Cars run on alcohol.
Higher than even the best engines in the 60s running on premium leaded gas.
regards
Mech
Old 12-06-2010, 09:09 PM   #163 (permalink)
The free piston also eliminates the leverage concerns with rods and pistons. The calculated efficiency in the EPA docs from 5 years ago was 58%.
http://www.sunpower.com/lib/sitefile...ns/Doc0083.pdf
http://www.freepistonpower.com/fp3.aspx
Free piston engines can also be configured to be linear alternators, which if they ever get to that range of efficiency could be the combination for a battery electric car with a free piston engine replenishing the battery or driving the wheels directly, with a regenerative hydraulic braking system that worked on the non driven axle.
That would create an existing platform that could easily be transformed into a pure electric, hydraulically regenerated vehicle when battery technology gets to the point where range and cost-life expectancy, and safety issues are resolved.
regards
Mech
Old 12-06-2010, 09:24 PM   #164 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by Old Mechanic View Post
Lets look at it another way, bsfc for most small passenger car diesels are right at 200 or just slightly lower in their sweet spot (generally speaking). For gas engines it's right at 250 (also generally speaking). Take 200 and divide that by .88 and you get 227.2, round that off to 227 and you have more than 50% of the difference due to the energy content of the fuel.
sorry dude, but bsfc is by weight (grams), not volume, and gas and diesel are about the same in the weight department (gas is actually a little higher)
http://upload.wikimedia.org/wikipedi...gy_density.svg
I think UFO explained the effects of increased compression ratio pretty well, higher expansion ratio=more energy extracted.
Old 12-06-2010, 09:24 PM   #165 (permalink)
Looks similar to your original configuration Neil.
regards
Mech
NeilBlanchard (12-07-2010)
Old 12-06-2010, 09:30 PM   #166 (permalink)
Super-Efficient Free-Piston Engines Could Replace Traditional Gas and Diesel Engines : TreeHugger
If they can get 50% direct electric conversion imagine what that would do for the volt or a smaller one for the leaf.
regards
Mech
Old 12-06-2010, 09:45 PM   #167 (permalink)
Well, not quite the same. This is a turbine, his was a piston engine.
Old 12-06-2010, 09:47 PM   #168 (permalink)
Understood but the configuration looked similar.
regards
Mech
Old 12-06-2010, 10:16 PM   #169 (permalink)
The original atkinson cycle engine which was invented to get by Otto's patents.
Animated Engines, Atkinson
regards
badger
Old 12-06-2010, 10:35 PM   #170 (permalink)
Atkinson is what I would consider to be "high overlap". Dynamically intake charge and compression would increase with engine speed.
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
The Easy Leg: Vehicle Efficiency natefish Off-Topic Tech 17 05-19-2010 04:52 PM
Vehicle Efficiency Improvements SVOboy EcoModder Blog Discussion 24 12-07-2009 10:19 PM
World’s cleanest internal combustion engines? blueflame EcoModding Central 6 02-28-2009 08:13 PM
Low-Drag Trucks: Aerodynamic Improvements & Flow Control System Boost Fuel Efficiency OokiiMamoru Aerodynamics 5 06-15-2008 11:38 PM
