12-06-2010, 09:01 PM
#161 (permalink)
Bus - '94 Ford School Bus huge Stupid - '01 Chevy Blazer LS 90 day: 21.38 mpg (US) hawk - '00 Honda Superhawk
Once again, effects of CR on power
Engine Compression Ratio - Tech - Popular Hot Rodding Magazine
Now, you dont have to believe it at all. In fact, you dont have to read it. But ignoring facts doesnt make your imagination reality. That is only unfortunate for you. Diesel and gasoline engines benefit greatly in their efficiency from higher CR's.
12-06-2010, 09:04 PM
#162 (permalink)
Agreed autoteach.
http://www.greencarcongress.com/2010...1020.html#more
The new Mazda has a CR of 14to1 close to what Indy Cars run on alcohol.
Higher than even the best engines in the 60s running on premium leaded gas.
regards
Mech
12-06-2010, 09:09 PM
#163 (permalink)
The free piston also eliminates the leverage concerns with rods and pistons. The calculated efficiency in the EPA docs from 5 years ago was 58%.
http://www.sunpower.com/lib/sitefile...ns/Doc0083.pdf
http://www.freepistonpower.com/fp3.aspx
Free piston engines can also be configured to be linear alternators, which if they ever get to that range of efficiency could be the combination for a battery electric car with a free piston engine replenishing the battery or driving the wheels directly, with a regenerative hydraulic braking system that worked on the non driven axle.
That would create an existing platform that could easily be transformed into a pure electric, hydraulically regenerated vehicle when battery technology gets to the point where range and cost-life expectancy, and safety issues are resolved.
regards
Mech
12-06-2010, 09:24 PM
#164 (permalink)
needs more cowbell
Originally Posted by Old Mechanic
Lets look at it another way, bsfc for most small passenger car diesels are right at 200 or just slightly lower in their sweet spot (generally speaking). For gas engines it's right at 250 (also generally speaking). Take 200 and divide that by .88 and you get 227.2, round that off to 227 and you have more than 50% of the difference due to the energy content of the fuel.
sorry dude, but bsfc is by weight (grams), not volume, and gas and diesel are about the same in the weight department (gas is actually a little higher)
http://upload.wikimedia.org/wikipedi...gy_density.svg
I think UFO explained the effects of increased compression ratio pretty well, higher expansion ratio=more energy extracted.
#165 (permalink)
Looks similar to your original configuration Neil.
regards
Mech
12-06-2010, 09:45 PM
#167 (permalink)
Well, not quite the same. This is a turbine, his was a piston engine.
12-06-2010, 09:47 PM
#168 (permalink)
Understood but the configuration looked similar.
regards
Mech
12-06-2010, 10:16 PM
#169 (permalink)
The original atkinson cycle engine which was invented to get by Otto's patents.
Animated Engines, Atkinson
regards
badger
12-06-2010, 10:35 PM
#170 (permalink)
Atkinson is what I would consider to be "high overlap". Dynamically intake charge and compression would increase with engine speed.
