Old 04-17-2011, 05:12 PM   #11 (permalink)
Originally Posted by Old Tele man View Post
...ah-h-h, but that same "clutch" would work great on an alternator!
Yes. Plug in lipo battery in the trunk to run all your electrics including PS, AC etc for a couple of hours then have a 200a alternator with a clutch to kick in when you run down the battery. Also engage the clutch every time you press the brake pedal while in gear.
Old 04-29-2011, 11:38 PM   #12 (permalink)
Hi, I have fitted the remote clutch to the fan on the Landcruiser and at the same time fitted the quieter assymetrical blade and although I cant see any difference in power on the Butt Dyno, I must be saving something and I can now here the tappets rattling. Alternator clutch sounds good but there must be a way to hook it up so as it is engaged not only when you put your foot on the brake but also when you take your foot off the accelerator and the car is on a certain incline and speed so the clutch knows you are coasting down a hill. I believe Honda used the drag of alternators to slow down a car at sometime in the past. Total cost to make my clutch was about $60 and that included a new belt and a couple of sets of bearings. Steve
Old 05-01-2011, 09:25 PM   #13 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by tjts1 View Post
Check out a Mercedes 190e 2.3 or a 90s C220. These cars had a mechanical fan with electric clutch from the factory. There are many others. I replaced mine with a normal puller electric fan because it's more efficient and cheaper to replace. The electric coil is fixed on the water pump behind the fan pulley (doesn't spin).
I think it could work good on a power steering pump. You only need it at low speeds...
