Old 11-27-2009, 11:32 PM   #1 (permalink)
Playslikepage71's Avatar
The Batmobile - '03 Oldsmobile Alero
90 day: 31.13 mpg (US)
Electric superchargers with promise
Has anyone here checked out this site?
Super Power Charger
These guys look legit. With a deep cycle battery and a swap to a smaller motor, any car could be eco and with the flip of a switch (one of those cool, red, James Bond, don't-touch-that-button looking ones), turn into a capable speedster.
This could be part of my Corsica project. I could swap to the little I-4 bugger with one of those. Too bad they cost a boatload.
They're working on a motorcycle version which could make for an interesting ecobike. Can anyone say literbike crushing 250?
Old 11-28-2009, 12:22 AM   #2 (permalink)
Draco - '89 Ford F150 ext cab shrt bed XLT Lariat
90 day: 16.45 mpg (US)
Draws way to many amps. Regular exhaust driven turbo charging is much much more efficient.
Because we are big dumb redneck Americans and we only want V8s that thunder and use lots of gas pushing our empty Super Duties down the highway at 100 MPH in the fast lane while warming our butts in heated leather seats and chowing down on double quarter pounders and texting on our cell phones. We cant understand non-V8 engines because that ain't whut NASCAR uses...
Not this American.
Old 11-28-2009, 01:03 AM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Playslikepage71 -
Interesting. $1849 minimum ?!?!?!?!?
CarloSW2
American Solar Energy Society
Old 11-28-2009, 02:06 AM   #4 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
There are a few things missing from their test.
They need to put some load on the turbo through inlet and outlet simulation.
1) They need to put the compressor housing on the unit.
2) They need to create back pressure to their claim of 6 to 8 psi intake manifold pressure.
Now they can measure the turbos shaft speed. Doing these two things will drop the shaft speed drastically.
Then after that it would be wise to tell us how much their turbos flow in lbs/min.
But they kinda already told us this is not even close to what a exhaust turbo can produce in the way of power. A meth/h2o injection kit will not help alone if the turbo flows anywhere close to what an exhaust turbo would. You will need to run bigger injectors also, even at only 6 psi.
Most Hondas today you can have a complete turbo kit with management for around $1500.00
On my sons car were only in it $1000.00
I wrote them to see how many lbs/min they flow. I will let you guys know as soon as I get a response.
EDIT My Bad
OK after reading more of their details I found that they do claim at a 20% decrease under load, but their not saying how much load? Plus I found they are claiming you should run larger injectors for max performance.
The main thing is how much do they flow in lbs/min. This can be used to compare apples to apples.
Pressure Gradient Force
The Positive Side of the Number Line
Old 11-28-2009, 02:34 AM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Just hook a leaf blower up to a Metro G10 and drop it in your lifted 4x4... that'll get you through anything.
Old 11-28-2009, 02:42 AM   #6 (permalink)
Electric.... magnetic... whats the difference?
Get one of those and glom onto a semi.
CoastRider (11-28-2009)
Old 11-28-2009, 07:20 AM   #7 (permalink)
It's legal to chain tow on highways, ain't it? I"m thinking grappling hook... those step bumpers on big-truck trailers are mighty big targets, and big trucks are more efficient than even most 4 bangers, right?
Old 11-28-2009, 11:58 AM   #8 (permalink)
Except then you have the same problems as with drafting: you've got to keep 100% alert, or you're under the truck :-)
Imagine instead a telescoping/articulated arm with an electromagnet on the end. Come up behind a truck at cruising speed, extend the arm, flick the switch, and suddenly your fuel consumption drops to just what's needed to power the magnet.
If you wanted to get slick, you could even build in a shock absorber for a more comfortable ride.
Old 11-28-2009, 12:05 PM   #9 (permalink)
It's not like turbo charging doesn't also draw amps. It's a myth that a turbo scavenges free energy. Adding more backpressure with a turbine causes the piston to have a harder time moving up.
Old 11-28-2009, 12:07 PM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
braking can be handled by the uhaul style brake actuator, where the coupling applies the rear vehicle brakes based on how hard it is trying to push the front vehicle.
You could do that for a fairly long chain, problem is making sure the front driver doesn't like to play "crack the whip" without sufficient warning, and of course determining how to share the fuel bills.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Milwaukee Electric Car Club (Running EVent!) bennelson Events & Meet-ups 18 10-17-2011 11:04 AM
100 mile range Ranger EV? Frank Lee Fossil Fuel Free 10 08-05-2010 12:09 PM
Article: Electric Subaru Due in 2009, One Year Early MetroMPG Fossil Fuel Free 8 08-29-2009 12:19 AM
