Old 01-22-2012, 04:18 PM   #11 (permalink)
Don't be fooled about "engine speed" by only looking at crankshaft rpms:
Most powerful diesel in the world: 98" stroke at 102 rpm = 1,666 ft/mn piston speed
Honda 50cc Super Cub at max fuel efficiency speed: 1.63" stroke at 4300 rpm = 1,168 ft/mn piston speed.
Hmmmm.
Yes one is a supercharged two-stroke diesel and one is a four stroke gasser. Different engine types seem to have different piston speed ranges for max fuel efficiency.
You can easily drop off the bottom end of the engine's efficiency zone by doing that.
FWIW, that is AVERAGE piston speed. If you look at the PEAK piston speeds, you might find some interesting results.
But to do that, you must do a bit of math and know the Rod length and stroke.
Old 01-22-2012, 04:21 PM   #12 (permalink)
I think as concerning fuel efficiency, we want to look at average piston speeds.
If we are getting into the nuances of intake and exhaust tuning, then peak piston speeds get more relevant.
Old 01-22-2012, 04:26 PM   #13 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Originally Posted by drmiller100 View Post
Apparently in some places Expansion Ratio is used instead of Compression Ratio.
For an Otto-cycle engine they are interchangeable, for Atkinson, ER is often significantly higher than CR.
Edit: Damn you Frank!
Old 01-22-2012, 04:28 PM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Is there a more accurate predictor than piston speed? Assuming relatively constant VE/RPM. I don't quite understand why piston speed alone is a factor, but I could understand that there is an optimal rate of expansion for the combustion gasses, and that the combustion chamber should not overly retard, or outrun the expanding gasses, or mimize the discrepancy anyway. So that it would be a function of bore*stroke or something.
Old 01-22-2012, 04:31 PM   #15 (permalink)
^Yeah.
I think it has to do with how much combustion heat energy pushes on the piston vs dissipating into the cooling system.
Too slow rpm = more time for heat to go into coolant
Too fast rpm = less push on piston; more internal engine friction
dcb (01-22-2012)
Old 01-22-2012, 04:45 PM   #16 (permalink)
The larger bore sizes have lower cylinder wall surface area as a percentage of displacement, so they will also have higher efficiency. Optimal piston speed is, as Frank already posted, the ideal point between the excess losses of the two extremes.
Other factors are the harmonics of induction and exhaust pulses and how they can reduce pressure waves which would affect in cylinder compression and exhaust scavenging. Also the amount of residual exhaust remaining in the combustion chamber which would tend to increase efficiency to a point, one reason why highly scavenged exhausts usually produce lower mileage.
Combining gas and diesel engines could yield best of both worlds
regards
Mech
Old 01-22-2012, 06:00 PM   #17 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I've read that a long stroke relative to rod length increases stress on certain engine components. Does this mean that it increases friction?
Are we talking rod/stroke ratio, or absolute stroke length? Can you have a good rod/stroke ratio and still approach an "ideal" stroke length simply by building a bigger engine?
Also, why does increased stroke length increase efficiency anyway?
Old 01-22-2012, 06:54 PM   #18 (permalink)
longer rod = more better. more efficient, more power, more everything, but slower maximum piston speed, which again, is better.
Old 01-22-2012, 06:59 PM   #19 (permalink)
Sigh.
Expansion ratio - Wikipedia, the free encyclopedia
if we want to get really picky, the Otto by definition has different compression then what you are calling expansion because of exhaust valve timing differences then intake.
So Frank. How does this affect efficiency for mileage? (hint: variable cam timing).
Old 01-22-2012, 07:10 PM   #20 (permalink)
Always a trade off in reciprocating engines. Longer rods and longer stroke generally give you more torque at lower RPM, but also increase reciprocating mass which will reduce efficiency.
I think the 225 Chrysler slant 6 had a 3.5 inch bore and a 4.5 inch stroke.
regards
Mech
