Old 01-01-2021, 04:50 PM   #11 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Originally Posted by 19bonestock88 View Post
Yeah I was figuring to just add a second coolant temp sensor that way each PCM got solid data. Given that the crank signal and VSS are just a pulse, would it even matter that the signal was split between two PCMs?
It wouldn't matter that the signal was shared - just has to be shared correctly.
It'd be wise to get the wiring diagrams for each PCM (I found mine on Google).
Check those and confirm the intended circuit each PCM requires..
I'm thinking along the lines of same operating voltages, and then ensuring the PCMs are of sufficient high resistance in the closed circuit state to not draw too much current.
Old 01-01-2021, 05:12 PM   #12 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I’m working on getting the diagrams as we speak and then will work on sourcing the other PCM and engine harness. Then again it might be simpler than I originally thought, I’ve heard of Cobalts that were simply PCM swapped for dirt track use
My current Ecotec project...
My last Ecotec project...
Old 01-02-2021, 10:26 PM   #13 (permalink)
Team Saturn
It might be that this was a simpler endeavor than I thought. Apparently I might be able to just re-pin the PCM connector and run the P11 PCM and have some warning lights on
Old 01-02-2021, 11:26 PM   #14 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
It says that I have a p11 pcm in my l200, also in my 02 Alero. Both are throttle cable cars not drive by wire.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 01-02-2021, 11:29 PM   #15 (permalink)
Team Saturn
So apparently I can use an L series or N-body PCM as well as a J body? Interesting
