Old 10-29-2013, 04:44 AM   #1 (permalink)
jackbauer's Avatar
EV Automatic Gearbox Controller Project
Thought I'd start a thread on a new project I have just begun. Plan is to develop an open source arduino based controller for automatics. The ZF 5HP24 is my first victim as I need it for a new conversion project but also plan on looking at the 5HP18 and the CAN bus controlled 6HP26.
First installment is a general intro and look at the flexplate coupler design :
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 3 Users Say Thank You to jackbauer For This Useful Post:
KUSAW (12-18-2013), Ryland (10-29-2013), thingstodo (11-03-2013)
Old 11-03-2013, 12:45 PM   #2 (permalink)
jackbauer's Avatar
Part 2 : Looking at the range switch and working out basic software to control the valves.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
Old 11-03-2013, 03:56 PM   #3 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
subscribed
Old 11-07-2013, 03:42 PM   #4 (permalink)
jackbauer's Avatar
Part 3 : A quick look at the adapter plate :
www.evbmw.com
thingstodo (11-11-2013)
Old 11-07-2013, 07:33 PM   #5 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
very cool, do you forsee doing away with the torque converter before it is all sorted out?
The efficiency curve is my main reason for asking...
Old 11-08-2013, 03:56 PM   #6 (permalink)
jackbauer's Avatar
First look at the controller hardware
www.evbmw.com
Old 11-13-2013, 05:01 PM   #7 (permalink)
jackbauer's Avatar
More work on the adapter plate. Now finished and ready to be mated to the gearbox. Just hope the damn thing fits ....
www.evbmw.com
thingstodo (12-08-2013)
Old 11-18-2013, 02:41 PM   #8 (permalink)
jackbauer's Avatar
We have spin !!
www.evbmw.com
Old 11-18-2013, 07:12 PM   #9 (permalink)
P-hack's Avatar
wow! that trans is massive next to the motor. Do you already have some idea what the electrical pins do for controlling it?
Old 11-18-2013, 07:26 PM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Why not just use direct drive and eliminate losses?
