Go Back   EcoModder Forum > Classifieds > For Sale
Old 05-13-2015, 05:47 PM   #11 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That is a complex question, but almost guaranteed the transmission helps efficiency. It certainly helps acceleration. DC series wound motors like that operate at higher efficiencies based on rpm/amp load. Also, batteries like lower amp draw (as do the electronics), so you can keep rpms higher and treat them nicer which will extend range as well as battery life.
So if I understand, you're saying that the transmission in a car like this would help because the driver could select, for example, second or third gear and get 4000 or 4500 RPMs at 60mph and this would be good for battery life and EV range. Do drivers of such EVs do any gear shifting? Seems like the electric motor would destroy itself as soon as the driveline load was removed by the clutch.
Old 05-13-2015, 06:12 PM   #12 (permalink)
I'm not sure why it would destroy itself. You still have a controller, so when you go to shift you let off the 'gas' pedal. A lot of guys just opt to get rid of the clutch as it seems this guy has also done. Thats not really my cup of tea, but its quite common.
These motors are kinda backwards from a gas engine in how you operate them efficiently. You want higher rpms and low amps (amps is kinda equal to torque) and they're happier in general.
The Following 4 Users Say Thank You to Daox For This Useful Post:
California98Civic (05-13-2015), Cd (05-13-2015), Chrysler kid (05-14-2015), pgfpro (05-14-2015)
Old 05-14-2015, 04:52 AM   #13 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
Taking what Daox said a step farther... In a car like this around town you might cruise in second gear but shift to third for max acceleration. That is because with only 72 volts there might not be enough voltage to supply the max amps at higher RPM. Seems backward at first.
The Following 3 Users Say Thank You to hamsterpower For This Useful Post:
California98Civic (05-14-2015), Chrysler kid (05-14-2015), Daox (05-14-2015)
Old 05-14-2015, 10:10 AM   #14 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
I love the concept and the engine bay. With that small of a motor it seems like you could stack lithium ion batteries in the engine bay
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
